Old 10-15-2015, 02:11 PM   #1
TST
We just had to pull over as I had an alarm sound on the TST TPMS. The pressure is fine but the temp went to 280 something. I found a spot to park and checked everything out and it appears fine. Not hot to touch. I reset the monitor and it's not finding all the sensors. I'm not sure what to think. I guess I'll push on and see what happens. Of course it's in the front right.
Old 10-15-2015, 02:13 PM   #2
15berkxl's Avatar
Phil is it sensing low battery in the sensor.
Wayne
Wayne
15berkxl is offline   Reply With Quote
Old 10-15-2015, 02:15 PM   #3
No Wayne it's not.
Old 10-15-2015, 02:18 PM   #4
tmmar's Avatar
Phil,
Call TST and explain the problem to them and see if they can offer any assistance. (770) 889-9102.
Tom and Margaret
2014 Berkshire 390bh-60
Old 10-15-2015, 02:40 PM   #5
Thanks for the number Tom. I talked to them and she thinks it's a sensor battery issue. I have had the system for 16 months and haven't changed the battery. I thought they were good for two years. Not the case. One year or less dependent on use. I'll have to find some batteries.
Old 10-15-2015, 02:51 PM   #6
tmmar's Avatar
Phil,
Should be able to get the batteries pretty much anywhere that sells batteries. They are a fairly standard size.
Tom and Margaret
Old 10-15-2015, 03:06 PM   #7
Flybob's Avatar
Great place to order batteries Digikey.com
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 10-15-2015, 03:27 PM   #8
accumack's Avatar
Internet is the cheapest. I change mine once a year.
2011 Berkshire 390-rb-40, upgraded tires and front axle airbags, 2012 Jeep Wrangler 2 door, Blue Ox baseplate and BlueOx aladdin tow bar, Blue Ox Patriot brake system, wiring run through right frame rail and homemade led taillight bar.FB.
Ham KG5LTL.
accumack is offline   Reply With Quote
Old 10-15-2015, 03:32 PM   #9
tmmar's Avatar
This may be correct but if you are on the road travelling, I'm sure Phil would like to replace the battery as soon as possible. I know I would.
Tom and Margaret
Old 10-15-2015, 03:38 PM   #10
fonzie's Avatar
Radio Shack should have them in stock, if one is close
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
Old 10-15-2015, 03:49 PM   #11
I carry 10 spares in the container I made to hold the sensors so I can change them anytime. Order 10 or 20 spares Energizers on eBay about every year or 2.
Old 10-15-2015, 03:52 PM   #12
15berkxl's Avatar
What's up with Radio Shack they closed all ours up north saying Corp went bankrupt. I saw one in Ohio open and think I saw one in SC.
Wayne
Wayne
Old 10-15-2015, 05:08 PM   #13
Funny, the right front on the toad was running over badly yesterday. I figure it's the sensor going bad. All my batts are fresh. Going to swap LF and LR sensors and see if the overheat moves.
Boowho??
boowho is offline   Reply With Quote
Old 10-15-2015, 05:29 PM   #14
acadianbob's Avatar
I got my replacement sensor batteries at Walgreens!
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
Red Green coffee mugs
Old 10-15-2015, 06:09 PM   #15
Alright we stopped for the night and are camping at the local Walmart. Thanks to everyone that offered a fix. The tech agrees with Wayne that the batteries are low. I didn't get a low battery warning that I should have so its not a sure fix. She wants me to install new batteries and relocate my booster. She said that with out the booster the batteries run out faster. Makes sense. Sorry I didn't post sooner but I don't text and drive.
Old 10-15-2015, 06:10 PM   #16
Anybody remember what batteries the TST takes. I think she said A1365? I couldn't write it down. Maybe cl1350? I guess I can take one apart.
Old 10-15-2015, 06:24 PM   #17
The 507 sensors operate utilizing a CR1632 battery which is readily available and easy to change.
Phil just copied this not sure if those are the sensors that you have.
Joe & Lori
2014 Berkshire 390 RB-40
5456Mich is offline   Reply With Quote
Old 10-15-2015, 06:30 PM   #18
TST
Car 1632 it is. Thanks. I'll go check Walmart to see if they have them. Nice having big camp store.
Old 10-15-2015, 07:10 PM   #19
15berkxl's Avatar
Where?
Wayne
Wayne
Old 10-15-2015, 07:14 PM   #20
15berkxl's Avatar
Phil you should have gotten a low battery indicator. Unless it was really low but I would think you wouldn't get any reading.
Wayne
Wayne
