Originally Posted by Chester Hill
Check your inverter and push the re-set button on top. I had this problem with my 2011 also. I used another outlet on an extension cord until someone told me to check the inverter reset. Once reset, the tvs worked fine.
X2
Several outlets (including those for the tv) are often fed by the inverter.
If the breaker trips on the inverter, the outlets won't work even when connected to shore power.
Hopefully the OP figured this out by now.
This thread is a couple weeks old.
Days Camped ☼ '19=118 ☼ '20=116 ☼ '21=123 ☼ '22=134 ☼ '23=118☼ '24=86
