Old 08-31-2019, 10:50 AM   #1
Tv
We are new owners of a used 2011 Berkshire. We can not figure out how to turn on the tv in the livinvroom and bedroom. Seems there is no electric going to them.
Ldyatfcop is offline   Reply With Quote
Old 08-31-2019, 10:56 AM   #2
Are you plugged in to shore power?
2019.5 Rockwood 2509S
Toddupton is offline   Reply With Quote
Old 08-31-2019, 10:58 AM   #3
Yes
Old 08-31-2019, 11:10 AM   #4
Do the outlet have power? Are the TVs 120 volt or 12 volt
Old 08-31-2019, 11:23 AM   #5
There are sitches in the tv area and when I flip them on they are green so I assume there is. But I tried my phone charger in the plug and it's not charging. Is there a switch I need to flip?
Old 08-31-2019, 11:34 AM   #6
A32Deuce's Avatar
Look for any GFI outlets that may be tripped. They usually daisy chain them. Green light you get is antenna booster for the over the air antenna on the roof.
A32Deuce is offline   Reply With Quote
Old 08-31-2019, 11:38 AM   #7
cboss's Avatar
The 120V plugs are usually in series. Check to see if the GFI plug is tripped. If not then check the Circuit Breakers on the power panel.
Craig & Cath
2018 2902WS Rockwood Ultra Lite
2017 Ford F250 Lariat, 6.2 gas
Equalizer Hitch w/ 4-Point Sway Control
Days camped since 2016(retirement): 669
cboss is offline   Reply With Quote
Old 08-31-2019, 11:45 AM   #8
I have checked and rebooted the circuit breaker. As far as GFI we have 2..one in the bathroom and one in the kitchen, both checked out...we have the berkshire firestriver 39' 4 slides. Woukd there be more than 2?
Old 08-31-2019, 12:14 PM   #9
A32Deuce's Avatar
I have heard reference to one in the basement, but I don't know where.
Old 08-31-2019, 12:22 PM   #10
Hi everyone. Thank you so much for your help. Apparently the outlet is no good. I finally plugged the cords into a outlet that is close and everything lit up light a Christmas tree. Waiting for an extention for the actual tv as the cord is too short to reach. So problem solved. You are all great. Thanks again.
