Old 05-07-2012, 11:35 PM   #1
Berkshire 390QS
NO3putt's Avatar
Tv power
TV will lose power and then the power will come back on. It looks like only the TV circuit because the lights, microwave etc. Will stay on. This will happen even when we are connected to 50amp shore power. Any suggestion?
Some times it won't happen for two or three weeks, some times a couple time in one evening.
2009 390QS Berkshire
NO3putt is online now   Reply With Quote
Old 05-07-2012, 11:39 PM   #2
Herk7769's Avatar
This sounds like a loose connection in one of your daisy chained outlet boxes. This is a VERY dangerous condition and needs to be checked out by an electrician or at least someone knowledgeable in AC circuits.
HAM CALLSIGN - KC3FFW
Old 05-08-2012, 04:24 AM   #3
Hoo Dad's Avatar
I had this happen one time with a television in my home and it turned out to be a circuit board problem. I researched the make and model on line and found others had experienced the same problem. Worth a look.
2011 Rockwood 8285 WS
2011 GMC 3500 HD 4X4, 6.0, 4.10, SRW
Hoo Dad is offline   Reply With Quote
Old 05-08-2012, 06:34 AM   #4
Herk7769's Avatar
You are right.
It IS possible it is a TV only problem.
What threw me was the "lights" and microwave comment.
That made me assume it was the "entertainment" circuit of outlets.
The OP needs to clarify this.
Old 05-08-2012, 06:44 AM   #5
TURBS's Avatar
I had a 12 v tv do that for several years in my flagstaff tt.
Had to unplugg it and plug it back in.
Old 05-08-2012, 07:41 AM   #6
Berkshire 390QS
NO3putt's Avatar
All the other electrical items in the coach remain on and working, only the entertainment center goes out and appears to happen randomly.
Old 05-08-2012, 08:27 AM   #7
J_KHawthorne's Avatar
I suspect power surges...
We remove the 32" Legend flat screen from our rig when we're at home and use it here in the house.
I have noticed that it is extremely sensitive to the frequent power surges we experience during thunderstorm activity. Even though our house circuitry is surge-protected, the TV will cut out even though the surge seems to be too insignificant to trigger the large unit protecting the house.
Have you tried a small surge-protector at the outlet?
Jim & Kathy
2012 Crusader 290RLT TE, TrailAir flex pin: 2012 Toyota Tundra 5.7 SR5 Dbl cab 4X2 Tow, 4.30 gears, RideRite air, TRD cold-air induction & dual exhaust: Reese 16K Slider: TST tpms
Miles towed to date: 18,950 Nights camped 192
J_KHawthorne is offline   Reply With Quote
Old 05-08-2012, 08:36 AM   #8
Herk7769's Avatar
Plug in a small light in the same outlet your TV is plugged into and see if it flickers when the TV cuts in and out. If only the TV is effected it is a TV problem. If the night light flickers too it is a wiring problem.
Old 05-08-2012, 09:44 AM   #9
Berkshire 390QS
NO3putt's Avatar
Good idea I will do that now. Thanks for the help!:-)
