Old 10-13-2015, 04:45 PM   #1
Understanding the Magna Sine Inverter
I don't understand . LOL
Read through the manual last night and it may be something that I need to continuously read until something sinks in.
What I'm getting out of it is that it has a mind of it's own and will do the right thing.
Just put in the new batteries and just looking for it to keep them charged for the winter, not over charge, but just what is required to keep them from freezing or boiling over.
I will keep the coach plugged in all winter to a 20 amp life line, with the fridge running ( why I have no idea, but can't hurt it. right ? ) So basically just need to keep the batteries topped off when they drop.
There is a temp. sensor hooked up, between Bulk, Absorb, Float, and Full charge seems like it's a slam dunk, no worry, system.
Am I missing something ? I'd hate to ruin these new batteries .
Joe & Lori
2014 Berkshire 390 RB-40
5456Mich is offline   Reply With Quote
Old 10-13-2015, 09:17 PM   #2
silver's Avatar
Rather than working my Magnum 24/7 365 days a year I got two of these and and put one on each battery bank. Have worked great for me and batteries are always fully charged in the spring. I just turn off the master switchs when I put the coach to bed.
Your assumption of the Maguum is correct.
silver is offline   Reply With Quote
Old 10-13-2015, 09:46 PM   #3
Bluepill's Avatar
+1 on using the maintainers rather than the charger/converter. No reason to run the refer if you are not storing food, and bad idea to store food in case the refer quits.
Old 10-14-2015, 06:45 AM   #4
KennyGolub's Avatar
Does that have a switch for 6V to get your 6v batteries ?
Ken & Laurie
Retired Cleveland CPD
2019 Entegra Aspire 44W
2018 Jeep Wrangler Unlimited
KennyGolub is offline   Reply With Quote
Old 10-14-2015, 07:29 AM   #5
Amazon.com: Battery Tender 021-0127 Battery Tender Junior 6V 750mA Battery Charger: Automotive
Now if you read how this operates, sounds like what the Magnum is suppose to do automatically.
Joe & Lori
Old 10-14-2015, 09:08 AM   #6
KennyGolub's Avatar
I was just asking him because he said he got two for both battery banks. Wasn't sure if he counted one 12v as one bank or there was a switch on it for 6 volts to do the other bank.
Thanks,
Ken
Ken & Laurie
Old 10-14-2015, 09:42 AM   #7
15berkxl's Avatar
Joe I question why you want to run refrigerator over the winter. Depending on model you have i.e. Dometic or Norcold some models have automatic defrost. In order for it to come out of defrost temperature has to be above I believe 34 degrees. So unless you are storing in a heated building your frig will not run until spring.
Wayne
Wayne
15berkxl is offline   Reply With Quote
Old 10-14-2015, 01:59 PM   #8
Wayne we have a residential fridge, no real reason to run it I suppose. Regardless I want to make sure the batteries are happy .
Joe & Lori
Old 10-14-2015, 03:20 PM   #9
Joe it sounds like you plan to spend some time at the MH this winter. If so I don't see any reason you can't keep the fridge going all winter. I can't see a down side and it would be nice to have food and beverage if you spend the day working on it. I always hated shutting mine down. Now I never do.
Old 10-14-2015, 03:29 PM   #10
15berkxl's Avatar
Rub it in Phil
Wayne
Wayne
Old 10-14-2015, 03:36 PM   #11
Originally Posted by 15berkxl View Post
Rub it in Phil
Wayne
X2
Joe & Lori
Old 10-14-2015, 03:43 PM   #12
And I thought that was subtle.
Old 10-14-2015, 03:51 PM   #13
Running a refrigerator during freezing temperatures is not a nice thing to do. It expects to cool and cannot heat. I always shut them down for the winter as there is no good reason to keep them working. If the temperature goes below 40, the reefer section will simply drop lower.
My advice is to shut it down and leave the doors open.
2015 335DS
ScottBrownstein is offline   Reply With Quote
Old 10-14-2015, 03:58 PM   #14
So after reading all the advice on here to shut the fridge down for the winter , I'm thinking to listen to what you're all saying and keep it off. If I go out there to do some work I'll just throw a six pack in a snow bank somewhere for a bit.
Joe & Lori
Old 10-14-2015, 03:59 PM   #15
This is a residential refrigerator does that make a difference?
Old 10-14-2015, 03:59 PM   #16
LOL you said snow.
Old 10-14-2015, 04:01 PM   #17
Phil I was also thinking say if it's close to 0* in the coach the fridge would almost have to run in reverse so to speak to keep things in there from freezing. Does that make sense ?
Joe & Lori
Old 10-14-2015, 04:02 PM   #18
Actually no. An RV refrigerator uses a heating element to replace the propane heat when on shore power. I would never think of running anything like that all winter and in temperatures below 40! The residential has a regular compressor. Neither is designed to operate in temperatures below freezing.
2015 335DS
Old 10-14-2015, 04:41 PM   #19
Subtle like a brick😛
Paul
Paulie Boy is offline   Reply With Quote
Old 10-15-2015, 05:36 PM   #20
X2
X3!!
boowho is offline   Reply With Quote
inverter
