Old 05-31-2016, 07:53 PM   #1
Update on Awning Fix
Last year I posted in this thread:
Awning Winder Shear Pin?
Well, I finally got around to fixing things this spring and got a pleasant surprise. I knew that the motor shaft was spinning inside the cap on my main awning tube. When I took it apart, the shaft has one flat side and it spun inside the aluminum cap essentially making a round hole (it was still tight, but when under tension, it would spin). I called Carefree of CO, but was told I couldn't just buy the cap (1. they don't make them any more, and 2. you have to buy the entire motor assembly ).
But Chris (tech support at C of C) said to check the other end. He said they should have the same shaft (non-motorized) and it might be interchangeable. Sure enough, it had the same shaft and I was able to just swap the two end caps and I am back in biz.
Hopefully this will help someone.
______________________
Mark & Karla + 2 Kitties
2008 Berkshire 390-QS
Bigfork, Montana
smo99 is offline   Reply With Quote
Old 05-31-2016, 08:07 PM   #2
hordok's Avatar
Great tidbit to file in the "if it happens to me" list.
Glad it worked out for you and thanks for sharing.
2016 Charleston BH
hordok is offline   Reply With Quote
Old 05-31-2016, 08:12 PM   #3
Is there anyway to add a reinforcement of some sort to the good end cap to prevent a reoccurrence?
Old 06-01-2016, 08:48 AM   #4
There are two things I can think of to prevent a re-occurence (ok, maybe 3). First, don't drive in crosswinds (Doctor it hurts when I do this--then don't do it!). Second, I'm going to look for a way to lock awning down with a hook or something to prevent it from ever unfurling while underway--there were a couple ideas posted on my original posting (see link in my first update post in this thread). And finally, I think one might be able to drill a hole through cap and shaft and put in a pin...but it would make future repair or removal harder.
And I just did a search and there are companies out there that do make locking mechanisms here's one: http://awninglock.com/
Bigfork, Montana
Old 06-01-2016, 10:42 AM   #5
AREA51's Avatar
I had the same thing happen this winter. Bought the new motor assembly and saved the old one with the plan to drill and pin the end cap to the shaft. I had looked at a video about the possibility of swapping the end caps but did not do that. It is a shame that you have to buy the whole assembly just to replace a slide on part. Looks like (a few bucks Vs. $250+) this is a pure rip off by Carefree.
GOOD LUCK
AREA51
AREA51 is offline   Reply With Quote
Old 06-01-2016, 04:01 PM   #6
I haven't had this happen on my Georgetown Awning but had it happen to one of my Slide Outs. I did email Keith and he gave me Wilson Forbes contact information. Keith believes they work also for these also.
David L Horton
2016 Georgetown 328
dphorton is offline   Reply With Quote
awning
