Old 10-07-2013, 06:18 AM   #1
EJM4's Avatar
Vent Valve Location ??
We are getting a black water tank smell in the vanity of the coach. Does anyone know if there is a valve or anything plumbed in the system that I could check to make sure it is operating properly?
Earl
2013 Berkshire 390BH / 360hp
EJM4 is offline   Reply With Quote
Old 10-07-2013, 07:13 AM   #2
Dave_Monica's Avatar
Do you know if your toilet is a Dometic model 300?
Here's a link to a previous thread that deals with the same issue... Dometic model 300 odor problem and replacement
Dave
Old 10-07-2013, 07:56 AM   #3
EJM4's Avatar
I believe it is the 310 since it is porcelain.
Earl
Old 10-07-2013, 08:13 AM   #4
It could also be a "cheater" valve. See this:
What's that smell ????
Old 10-07-2013, 08:23 AM   #5
EJM4's Avatar
Thanks Barry - I will take a look in there this evening.
Earl
Old 10-07-2013, 09:46 AM   #6
Mmnsc's Avatar
We had a black water smell in our 390bh especially when the exhaust fan was on. It turned out to be the back flow preventor valve mounted on our washing machine drain line. The valve allowed the smell to come in until it was changed. You might want to check to see it you have this valve installed anywhere on your system. Good luck
Mmnsc is offline   Reply With Quote
Old 10-07-2013, 05:06 PM   #7
EJM4's Avatar
I looked this evening and the cheater valve appears to be located behind a wall. There is also what appears to be vent tube that the sink drain may be connected to instead of a cheater valve.
Why would the grey water smell like black water if the valve is bad ?
Earl
Old 10-07-2013, 05:28 PM   #8
I don't know why, but I can only tell you that my grey tank smells pretty much as bad as my black tank. I'll admit that I haven't spent much time differentiating between the two aromas however. ;-)
Old 10-07-2013, 05:37 PM   #9
Mmnsc's Avatar
The valve that was giving me the trouble and smell did not appear to have any moving parts. Although I thought the washing machine water was going into the grey tank we still had the smell like it was coming from the black water tank (pretty nasty). Once the back flow preventer valve was located and the dealer changed the back flow preventer valve the smell went away. Apparently the grey water tank develops foul odors from food remnants etc that go down the drains in the kitchen and bath. I hope you find the solution to your problem quickly as we know how unpleasant it can be. Good luck
Old 10-07-2013, 06:01 PM   #10
EJM4's Avatar
Did they have to remove the washer to replace?
I hate to cut up the wall inside the vanity on a goose chase.
Earl
cat, location, vent
