Old 12-04-2015, 09:59 AM   #41
gasman94's Avatar
Originally Posted by I-RV View Post
To my knowledge, the high beam does not flash with the headlights off. I'd like to have someone say that is not the case, however.
Hank
I'll try to check mine today, Hank.
Rich
gasman94 is offline   Reply With Quote
Old 12-04-2015, 10:12 AM   #42
2011 Berkshire 390BH
Superchief's Avatar
Just saw this post. If I remember correctly when I went to Freightliner Camp, someone asked about the smart wheel. The instructor said it was installed by Freightliner and that the additional cost was around $3000. So, I guess that Forest River would have to order it from Freightliner when they order the chassis. Craig
Craig
Finally completed all State visits in August 2011 with a trip to North Dakota.
Superchief is offline   Reply With Quote
Old 12-04-2015, 10:31 AM   #43
15berkxl's Avatar
Hank
Hank if I remember correctly the Berk low beams are on as running lights as long as as MH is in D. So turning lights on and off as courtesy lights won't do anything. Someone needs to stand in front of MH to confirm this.
Wayne
Wayne
15berkxl is offline   Reply With Quote
Old 12-04-2015, 10:32 AM   #44
gasman94's Avatar
3 grand? I'm in the wrong business!
Rich
Old 12-04-2015, 10:36 AM   #45
CAT-RN's Avatar
That 3 grand from factory. No telling what it be aftermarket.
Russell
CAT-RN is online now   Reply With Quote
Old 12-04-2015, 01:33 PM   #46
I-RV's Avatar
Wayne
Wayne, For my 2012, if the rotary light switch is off, there is no front lights with engine running and in Drive. Also, see my response to Rich.
Hank
Gale & Hank- 2012 Berkshire 390BH
I-RV is offline   Reply With Quote
Old 12-04-2015, 02:10 PM   #47
I-RV's Avatar
Originally Posted by gasman94 View Post
Hank, maybe I'm missing something here, but don't high beams flash by partially pulling back turn signal stick?
Rich
Rich, I wish what you said is the case, but partially pulling the stalk back does nothing. The light controls are also somewhat quirky; let me show what I found:
The light control has three rotary positions and a push feature for the fog lights.
Off position: RV front is dark, fog button does nothing and cannot flash high beams with the stalk.
Middle (Running) position: Marker lights front and all around the RV. Fog lights do not work and cannot flash high beams with the stalk.
On position:
Running lights on and low beam (large reflector) or high beams (smaller reflector) if selected with the stalk. When high beams are on, the low beams go out; for which I would think that we would have way better light with both on. The fog lights will work in this position.
All of the above is applicable whether in Neutral or Drive.
Now for the quirky stalk To switch the high beams on, the staked need to be dragged back about an inch until it stops (no high beams yet), then completely released (another inch).
So if I wanted to flash the high beams twice to a vehicle in front, I would have to:
1. Make sure the High Beam (HB) blue light is not already on in the dash panel.
2 Pull the stalk back and release; HB goes on after release
3. Pull the stalk back and release; HB goes out after release
4 Pull the stalk back and release; HB goes on after release
5. Pull the stalk back and release; HB goes out after release
6. Make sure the High Beam (HB) blue light on the dash is out
Low and behold if you want to flash more times; you might want to have a pad with a pencil so that you can keep count as to where you are.
The stalk high beam feature works exactly like the left foot high beam switch on cars, eons back. Now I do not need all the features of the Smart Wheel (but they would be nice), but FR give me a break, the high beam control is butt ugly. I would even go for having the pushbutton control on top of the light switch do high beam flashing.
Now for all of you snoring and saying I could care less about High Beam flashing; I say that's your choice. However I do say for all to get to know how the front of your RV lights up and when, because it seems that many do not know.
Hank
Old 12-04-2015, 02:33 PM   #48
gasman94's Avatar
On position:
Hank
Hank, I went out to my storage place today and found out the same thing as you. I can't believe that there is no flash feature also. But, I guess the same criteria is not used that would be used in designing features for passenger cars. That being said, since freightliner is the largest class a chassis manufacturer, one would think that they would have some features tailored to the RV market. Anyway, thanks for the info, Hank.
Rich
Old 12-04-2015, 03:06 PM   #49
15berkxl's Avatar
VIP Smart Wheel?
Hank
Hank the problem is our 2015 XL does not have a rotary switch it has rocker switches.
Wayne
Wayne
Old 12-04-2015, 03:07 PM   #50
I-RV's Avatar
Rich, I would think that the criteria for High Beam flashing should be the same for cars, coaches and truck. Marker (running) Light flashing however isn't applicable to cars and many trucks have it. You do get Marker Light flashing with the Smart Wheel.
Hank
wheel
