Old 06-26-2014, 01:22 PM   #1
Thinkie's Avatar
Wardrobe Slide Out
I have a Berkshire 390bh and I close my extension this morning and when I try to reopen it opens about a quarter inch and it was my make a verry strange noise and it gets stuck.
Envoyé de mon iPad à l'aide de Forest River Forums
Thinkie is offline   Reply With Quote
Old 06-26-2014, 01:49 PM   #2
2011 Berkshire 390BH
Superchief's Avatar
Check out this link. There have been several pots lately about this same issue. Good luck! HELP!! Does anyone know about bunkhouse slide mechanism
Craig
Finally completed all State visits in August 2011 with a trip to North Dakota.
Superchief is offline   Reply With Quote
Old 06-26-2014, 01:50 PM   #3
Superchief's Avatar
Should be posts not pots. Thank you spell check!
Craig
Old 06-26-2014, 04:32 PM   #4
tmmar's Avatar
Thinkie,
sounds like you have the same problem that I had- the drive motor/transmission has gone bad. It is a one piece unit that drives the cables that open and close the slide. If you have a '14 coach it will be covered under warranty. It is a big pain to replace so it's best to have a tech do it.
Tom
Tom and Margaret
2014 Berkshire 390bh-60
Old 06-26-2014, 04:34 PM   #5
Thinkie's Avatar
Yes we have a 2014, we go see a dealer
Thank you
Old 06-26-2014, 07:58 PM   #6
stephencamiolo's Avatar
I have a 2014 390 BH and had the same issue the first weekend out. Mine ripped the motor off the wall. Warranty replaced it and I had then reinforce the mount with steel. Also make sure they replace it with the super high torque motor.
Works great now
stephencamiolo is offline   Reply With Quote
Old 07-11-2014, 09:04 AM   #7
Thinkie's Avatar
I go to the dealer and this is the gear that are broken, the pieces are arriving by plane yesterday, but he did not have time to repair before Monday. We need to open the slide out for the weekend, is that its can open by hand?????
Old 07-11-2014, 07:28 PM   #8
I'm pretty sure it will be stuck on the gear. See if you can recruit some muscle to push the slide, but don't force it if it doesn't budge.
CT Camper is offline   Reply With Quote
Old 07-11-2014, 08:14 PM   #9
Thinkie's Avatar
thank you. we will try to open it like that
slide, slide out
