Old 12-04-2018, 08:06 PM   #1
Terrilegacy's Avatar
Washer
I have a 2104 Berk and from day 1 have had problems with the clothes washer. It is always hard to get started. Has anyone else had problems? You push the start button and in 10 sec the door locked red light starts flashing but nothing happens
Terrilegacy is offline   Reply With Quote
Old 12-05-2018, 07:28 PM   #2
What washer do you have?
2017 Berkshire XL 40 BH
2015 Jeep Cherokee Latitude
Locomo14 is offline   Reply With Quote
Old 12-05-2018, 08:02 PM   #3
Whirlpool wfc7500vw2
Old 12-05-2018, 09:01 PM   #4
Iím pretty sure it is the door lock. Part can be found on e-bay and amazon. Do a search on you tube for how to video.
It may also be the water pump filter. Open panel on bottom front of washer. On the right side is filter, turn to open. Water will drain when opened so be prepared for that. Check for obstruction.
Good luck
Old 12-05-2018, 09:21 PM   #5
Good luck
Old 12-06-2018, 12:10 AM   #6
Dragonship Captain
Oscarvan's Avatar
Not sure which washer we have, but the procedure is to close the door, select the program and then depress start until lights come on... then it takes as much as 15 seconds for ANYTHING to happen. This is normal.
Read about our 2017 38A: https://dragonship.blog/
Oscarvan is offline   Reply With Quote
