Old 01-27-2016, 10:56 PM   #1
stephencamiolo's Avatar
Washer shakes the entire coach
Anyone have any ideas? When we run the washer and as it is spinning up or slowing down from spinning it shakes the entire coach. Anyway to secure or balance this thing?
stephencamiolo is offline   Reply With Quote
Old 01-28-2016, 12:24 AM   #2
7 Year Class A RV'er
Washer in our Legacy does the same thing. I think the main issue is that it IS anchored directly to the coach frame, which then transmits the vibration. I just figured it was a matter of "that's how it is".
2015 Legacy SR340 360RB with 2014 Wrangler Unlimited Toad
Gigi, Poppy and Sadie the Jack Russell (all 14 lbs of her)
Old 01-28-2016, 06:00 AM   #3
2014 360 QL
po 185's Avatar
mine does too.
2014 360 ql
po 185 is offline   Reply With Quote
Old 01-28-2016, 07:37 AM   #4
AquaMan's Avatar
After a long early morning drive to our destination, wife decided to try out the washer in our new GTown just before we laid down for a quick nap. All was fine until it hit the spin cycle and the bed started to vibrate. We looked at each other and started to laugh.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
Old 01-28-2016, 08:26 AM   #5
Just think in the 70s people actually spent money on a vibrating bed and you get it for free. 😀. Hopefully it's not too bad.
2019 Puma XLE 27QBC Toy Hauler
2005 Honda VTX 1300
2002 Goldwing 1800GL CSC Trike
2020 Ram 2500 Crew cab 6.5 bed
Ron & Shirley (Empty Nesters)
rmac04401 is offline   Reply With Quote
Old 01-28-2016, 08:31 AM   #6
AquaMan's Avatar
We actually don't feel it unless we are laying down. It's a little more pronounced in the rear of the coach, since that's where the W/D is. The rest of the cycles have no affect.
Old 01-28-2016, 01:09 PM   #7
RetiredRVer
My front load washer at home shakes my house.....I think it's just how it works!
checkmate99 is offline   Reply With Quote
Old 01-28-2016, 01:32 PM   #8
MilCop4523's Avatar
load balanced?
does it do it more with towels or blankets jeans only?
the anchoring very well could be the issue
is there a method to remove it and put some sort of rubber buffer on each leg and reattach so it acts as a damper?
TV 2018 Ford F250, hauling a 2018 KZ 331 TH 12 Sportster 5th wheel, packing a 2015 CF MOTO 800 U-Force SXS
MilCop4523 is offline   Reply With Quote
Old 01-28-2016, 01:37 PM   #9
marialee-Berkshire410qs
marialee's Avatar
Shake, Rattle, and Roll.
marialee is offline   Reply With Quote
Old 01-28-2016, 02:15 PM   #10
Canadian Full Timer
Yep, that's what they do, it seems. We always say that it helps "loosen" what's in the loo! LOL
Cherokeerose is offline   Reply With Quote
Old 01-28-2016, 03:59 PM   #11
BamaBob's Avatar
SHHHH! Be careful or some marketing type will start claiming how the W/D has a "Integrated Black Tank Rinse Mechanism"
Nights Camped: 2013 - 242014 - 422015 - 56Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 01-28-2016, 04:28 PM   #12
Rick_Geneseo's Avatar
My Phoenix is the same way. I like to do laundry at bed time. Its like one of the cheap motels of yesteryear with the bedside quarter boxes and the vibrating bed.
Rick_Geneseo is offline   Reply With Quote
Old 01-28-2016, 05:01 PM   #13
Plug It Right
I can only tell you what works for us. We added permanently mounted stabilizers about 10 years ago when I had had enough of the fact that the bi-pod we had been lugging around and using just wasn't going to work. We have been not only satisfied with no shaking when using the washer but love it when I can't feel dutch rolling around in bed or moving about in the bedroom. Hope it helps. Hugs Di
Dutch & Di is offline   Reply With Quote
Old 01-28-2016, 07:10 PM   #14
SternHappens's Avatar
We also have a 364TS, best time for a nap is when wife doing laundry, great for the back...
2015 Georgetown 364TS, '05 TJ flat, or '14 Fiesta 5 spd w/Tandem Tow Dolly HDXL 8x10, & EZGO Customized Cart
Days Out '17-25{Days in Shop 141}; '16-59; '15-56.
2011 Flagstaff V-Lite 30WFKS '14-24, '13-33, '12-36, '11-29, '10-23.
SternHappens is offline   Reply With Quote
Old 01-28-2016, 07:20 PM   #15
AquaMan's Avatar
Brings back to mind, the old joke about "doing a load of laundry". 😀
Old 01-28-2016, 08:31 PM   #16
One thing I have found in our 2011 Berk340RB is to make sure on our front loading washer that once you have loaded the washer is to feel for the clearance from the top of the clothes to the top of the drum of the washer. If you allow at least 6" free above the clothes it does some shaking but not nearly as bad when you "fill" the washer to the top.
Just a thought from DW of BooWho2
kaymfischer is offline   Reply With Quote
Old 01-28-2016, 09:54 PM   #17
Originally Posted by MilCop4523 View Post
load balanced?
Great idea
Looking at it, there's no rubber. It's just mounted to the wood cabinet it sits in. I'm going to remove it and place rubber pads under it to see if that helps. If I figure something out il post pics
Old 01-28-2016, 10:32 PM   #18
VinceU's Avatar
Great idea
You'll make it worse, the rotating drum is mounted internally with springs and load washers designed to accept the imbalance and shed to the casing. Much like engine mounting in autos, vibration must be modified as attached to the foundation. They all do it it seems.
Old 01-29-2016, 07:25 AM   #19
CAT-RN's Avatar
Well ours vibrates the bed & coach too. Just the way it is I guess.
As to the quarter vibrating beds of 45 year ago. The washer has the same effect when we are in bed. I just for some reason don't get the same result tho !!
Russell
CAT-RN is offline   Reply With Quote
Old 01-29-2016, 08:22 AM   #20
Russell
I agree 100% with ya Russell.
Joe & Lori
2014 Berkshire 390 RB-40
5456Mich is offline   Reply With Quote
tire
