Old 10-15-2015, 08:06 PM   #41
Ford Idaho's Avatar
Originally Posted by boowho View Post
Huh??
Boowho??
https://www.google.com/?gws_rd=ssl#q=def+delete
Running a diesel engine without def is totally doable.
Old 10-15-2015, 08:10 PM   #42
I own a 2007 chev. Duramax diesel, do I have one of these DEF tanks. I don't see any gauge showing this or any kind of a alarm.
Gee Whiz is offline   Reply With Quote
Old 10-15-2015, 08:12 PM   #43
ferguson65's Avatar
Just crossed this and I'll clear up a few things........DEF will crystalize if left out or the tank goes dry. The crystals will dissolve once more (liquid) DEF is added. The DEF will freeze. It's unavoidable in cold weather. The tanks/ pumps and lines are designed for this. Once the engine is shut down you will hear a pump run, that's the DEF being pumped back to tank so it doesn't freeze in the lines or pump. The tanks are designed so they can't be filled to the top to allow the freezing DEF somewhere to expand. DEF has a shelf life, which on the upper end is around 2 years in perfect conditions, approx. 60-65F. Anything higher will reduce shelf life down to approx. 2 months at 104F ambient.
In my 6.7 Ford I wait until it tells me it wants DEF, and then add 2.5 gals. My work truck (12 Pete with PX8) I add 5 gals once the gauge hits 1/4 (10 gal tank). No need to keep the tanks full.
2013 F350 dually
2015 Palomino Puma 351THSS Premier Edition
2015 Nights camped 15
2016 Nights camped 5
ferguson65 is offline   Reply With Quote
Old 10-15-2015, 08:13 PM   #44
No I believe DEF is 2010 and after
Old 10-15-2015, 08:34 PM   #45
riverrat958 is offline   Reply With Quote
Old 10-15-2015, 08:50 PM   #46
15berkxl's Avatar
The FL chassis has a heater in the def tank so if you run your RV in winter for those not fortunate enough to be in Florida the def will liquefy quickly.
Wayne
Wayne
15berkxl is offline   Reply With Quote
Old 10-15-2015, 09:11 PM   #47
It can be 122 deg's here in phoenix so DEF doesn't last long but yet it does.... Odd stuff. Packaging on the 2.5 gal will say store below x degree and we never get that cool in summer! Oh well, it's what we get living in a convection oven!
Jc
2014 400BH-60
jcowles3 is offline   Reply With Quote
Old 10-15-2015, 09:25 PM   #48
Oh....
boowho is offline   Reply With Quote
Old 10-15-2015, 09:59 PM   #49
Just order that software from Volkswagen.
Old 10-15-2015, 10:34 PM   #50
NICE!
Jc
2014 400BH-60
Old 10-15-2015, 10:49 PM   #51
B47
Oh....
I like your Harvey Korman quote from Blazing Saddles, but I have always thought Cleavon Little's (Bart) response when he was told "l heard you were hung" and he said "I am."was the funniest line in the complete movie.
Great movie.
Old 10-16-2015, 07:39 AM   #52
Great movie.
Me too!
Old 10-16-2015, 07:59 AM   #53
camper1999's Avatar
Originally Posted by Springerdad View Post
Be careful,,,, DEF has a shelf life of about two years. If you keep topping your tank off you'll have old fluid in there. There's even a 'born on' date on the containers so youll know how fresh it is.
X2 Between spring and fall when I am using my truck a lot, for trips, I top off the tank. During the winter months I do not top off the tank so all the old DEF will mostly gets used up. In winter if you do top off you want to be careful not to overfill the tank, since DEF freezes and will crack the tank if there is no room for it to expand.
2011 GMC 2500HD Diesel
Old 10-16-2015, 01:46 PM   #54
Great movie.
Well, did you know that this line was in the original script, but was cut?
Madeline Khan : "It's twoo, it's twoo". (It's true, it's true)
Clevon Little: : "Easy baby, you're sucking on my elbow".
Boowho??
Old 10-16-2015, 02:08 PM   #55
B47
BW - no,I didn't know that. I would of loved to hear that in the movie.
Mel Brooks is one of the greatest comedy writers in the would IMO. Even at 89 years old.
Old 10-17-2015, 03:38 PM   #56
fredhardy's Avatar
I picked up 2 1/2 gallons of DEF today just in case this happens to us! Thanks for the heads-up!
fredhardy is offline   Reply With Quote
Old 10-17-2015, 04:29 PM   #57
Just a heads up, a $15.00 battery pump will make life much simpler. Wait till you try and pour the DEF from the jug to the tank. Click image for larger version
Name:	ImageUploadedByForest River Forums1445117376.284129.jpg
Paul
Paulie Boy is offline   Reply With Quote
Old 10-17-2015, 04:32 PM   #58
accumack's Avatar
I'm cheap I have a hand pump that cost $7. LOL
2011 Berkshire 390-rb-40, upgraded tires and front axle airbags, 2012 Jeep Wrangler 2 door, Blue Ox baseplate and BlueOx aladdin tow bar, Blue Ox Patriot brake system, wiring run through right frame rail and homemade led taillight bar.FB.
Ham KG5LTL.
accumack is offline   Reply With Quote
Old 10-17-2015, 04:32 PM   #59
Have to get me one of them.
Joe & Lori
2014 Berkshire 390 RB-40
5456Mich is offline   Reply With Quote
Old 10-17-2015, 04:36 PM   #60
Make sure you run a couple of gallons of clean water through the pump when finished so the DEF doesn't crystallize. Just clean water, nothing else.
Paul
