Old 10-15-2015, 04:34 PM   #31
I-RV's Avatar
I believe adding DEF, freshens the older amount in the tank. I put on 34,000 miles in 2 1/2 years which means that I am moving a lot of DEF. Others may have longer periods of standing still. DEF has been covered previously and storing at elevated temperatures, shortens its life. - Hank
Gale & Hank- 2012 Berkshire 390BH
I-RV is offline   Reply With Quote
Old 10-15-2015, 04:55 PM   #32
Anyone know the capacity of the tank on our Berks? I was able to put a total of about 8 gallons total in before it overflowed.
Also, I'm going to investigate a way of temporarily "cheating" (GASP) the sensor, in case I ever run out again. May not be possible, but if it is would be a great way to limp into a place to buy DEF.
Boowho??
boowho is offline   Reply With Quote
Old 10-15-2015, 05:08 PM   #33
tmmar's Avatar
Boo,
The DEF tank on the Berkshire holds 13 gallons.
Tom and Margaret
2014 Berkshire 390bh-60
Old 10-15-2015, 05:10 PM   #34
Ford Idaho's Avatar
Boowho??
(def delete)
Old 10-15-2015, 05:13 PM   #35
Originally Posted by tmmar View Post
Boo,
I thought so.... something ain't kosher here. After the engine quit, I was only able to get 8 gallons in before it overflowed.
That means there was still 5 gallons in the tank, that was unavailable to the engine.
Boowho??
Old 10-15-2015, 05:51 PM   #36
Boowho??
X2
Joe & Lori
2014 Berkshire 390 RB-40
5456Mich is offline   Reply With Quote
Old 10-15-2015, 07:18 PM   #37
15berkxl's Avatar
Sounds like a call to FL is in order.
Wayne
Wayne
15berkxl is offline   Reply With Quote
Old 10-15-2015, 07:43 PM   #38
Rodgers's Avatar
Originally Posted by Dennise View Post
But how do you know when it's full ???
My 2015 coachman Prism 2150LE has no gauge and my DEF tank and fill tubes are opaque. I don't want to run the risk of a 'blind' top-up and have the fluid come screaming up the fill tube then splashing the corrosive fluid all over the engine compartment.
Some say not to worry and just add fluid when low/empty warnings happen. Sure. Risking limited engine starts, 5 MPH maximum speed or even shut-down while giving unreliable and hard to access indication of DEF level is just plain stupid. Shame on you MBenz
I'm considering drilling a hole in my DEF tank and using some kind of 'dip-stick' to check the DEF level. Any ideas?
DEF fluid isn't corrosive it's a clear liquid. It will leave a white residue that will wash of with plaln water. WONT HURT PAINT on your truck or RV if you are worried about skin contact wear rubber gloves I do all the time for the diesel fuel. On the RAM it's next to the fuel fill. DO NOT PUT IT IN YOUR FUEL TANK at least a 10k repair.
Rodgers is offline   Reply With Quote
Old 10-15-2015, 07:53 PM   #39
Originally Posted by Ford Idaho View Post
(def delete)
Huh??
Boowho??
Old 10-15-2015, 07:55 PM   #40
Wayne
YEP.
I missed the call, but the help line did call me for a status today.
Will talk to them tomorrow.
Boowho??
