Old 10-17-2015, 04:48 PM   #61
Noted. Thanks Paul.
Joe & Lori
2014 Berkshire 390 RB-40
5456Mich is offline   Reply With Quote
Old 10-18-2015, 07:54 AM   #62
15berkxl's Avatar
You can buy those battery powered pumps at HD or Lowe's.
Wayne
Wayne
15berkxl is offline   Reply With Quote
Old 10-18-2015, 08:17 AM   #63
I-RV's Avatar
A lot of DEF info can be found at.......
The DEF Filling Bugaboo !!!
Hank
Gale & Hank- 2012 Berkshire 390BH
I-RV is offline   Reply With Quote
Old 10-18-2015, 08:20 PM   #64
Berkshire club
Berkshire Driver's Avatar
I mounted a RV water pump near my DEF tank in the compartment and wired it with a toggle switch when or if i need to use a 2.5 gal jug i use the pump takes about 3 min just gotta watch that you don't overflow that stuff ,and run water thru it when your finished don't want the crusties! used it 3 times and so far it still works it began as a test to see if the fluid would destroy the the rubber diaphragms in the pump.
2014 360QL-60 Mystic Garnet
Berkshire Driver is offline   Reply With Quote
Old 10-21-2015, 07:37 AM   #65
I-RV's Avatar
Glad to hear that I am not the only crazy one to build a pump. Here is mine..
See thread for more info.
Hank
Old 10-21-2015, 03:02 PM   #66
Well I guess if your Berk stays parked in the driveway the DEF should last a long time. Might be a project for down the road though. Looks good !
Joe & Lori
