Old 02-17-2015, 12:43 PM   #31
Good advice for trailers too. I had a stem leaking while vacationing in Florida.
gfarmcafe is offline   Reply With Quote
Old 02-17-2015, 01:56 PM   #32
JTN8's Avatar
Originally Posted by Gottawonder View Post
JTN8, if you look at Tireman9's post in the other thread, you'll see he references a 47/53 side-to-side ratio as common. That'd take your 10600 to 5618 on the heavier corner which would move you to 95psi on the front and another 5psi for buffer, based on the Goodyear G670 275/70R22.5. You may be fine at 90 but I'd rather run 5psi over than 5psi under. Family, luggage, fluids I wind up closer to the max axle ratings (12k and 19k) so I'm usually targeting closer to 100psi in the rear and 110-113 in the front. Hope that makes sense.
I have the same tires... Thanks for the info! I'll have to readjust my pressure.
Jason
Old 02-17-2015, 08:38 PM   #33
2013 Berkshire 390 BH-60
Jersey Guy's Avatar
Jason, what site number are you in? I will be flying in tomorrow and staying with friends in the west lot.
Mike
2013 Berkshire 390BH-60
Jersey Guy is offline   Reply With Quote
Old 02-18-2015, 07:17 PM   #34
JTN8's Avatar
D903... Stop on by!
Jason
Old 02-19-2015, 08:02 AM   #35
Jersey Guy's Avatar
That's over on the airport side isn't it?
Mike
Old 02-20-2015, 06:14 AM   #36
JTN8's Avatar
Yes it is. In between the airport runway and the road. Pretty much in the back and right of west lot
Old 02-20-2015, 10:14 PM   #37
JTN8's Avatar
Great meeting jersey guy tonight at Daytona Speedway! He is the first Berkshire owner I've met so far. Great meeting you and happy camping / travels to you!!! Hopefully we'll meet up again.
Jason
Old 02-21-2015, 06:33 AM   #38
Joedebrv's Avatar
Jason , what is your GVW ? I had my 2013 BH up graded (warranty) to 31,000. New tires 275-80R-22.5 Also had bigger air bags installed . How I found my coach was under rated was I put it on a CAT scale during my second trip out with it
Joedebrv is offline   Reply With Quote
Old 02-21-2015, 07:09 AM   #39
JTN8's Avatar
Mine is a 2014 which came with the upgraded suspension, airbags and tires from the Factory.
Jason
Old 02-21-2015, 07:15 AM   #40
Joedebrv's Avatar
What is your GVW?
