08-14-2015, 10:29 AM
Water cooling ac units
I think we all can agree that the 13500 btu ac units standard on our Berkshire are undersized for extreme heat. We're in Phoenix awaiting a new OTD awning and temps are running in the 112°+ range. Have any of you tried cooling the units with a spray of water?
Paul
08-15-2015, 01:35 PM
We added an 8000 btu Ac that vents out drivers window and helps a bit but all it proved to me was we need 45000 btu's in phoenix when temps are this hot. Or total shade on the entire vehicle. We live in phoenix so ... It's a dry heat my ...!!!
Jc
2014 400BH-60
08-15-2015, 01:40 PM
Here is a pic...
Jc
2014 400BH-60
08-15-2015, 01:52 PM
That's nifty. I'm stuck in Phoenix till Tuesday for a new OTD awning that I ordered from Al's RV. Supposed to be delivered Monday PM. Install Tuesday then headed to altitude for some cooler weather.
Paul
08-15-2015, 02:15 PM
It wouldn't hurt to give it a try. Monitor your temperatures and see if you get any improvement. Make sure that the A/C unit drain is completely open and don't use much volume for the spray, or you may flood your interior.
08-15-2015, 02:21 PM
Georgia Rally Coordinator
Yep next one you should get the two airs. Make a big difference. Later RJD
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
08-15-2015, 05:17 PM
Get three AC. At Goshen we had a chance to sit down with the powers that be in FR diesel. One of the discussions was cooling the MH. We strongly urged them to look at all aspects of cooling. Larger AC units and I feel more importantly doing a better job of identifying the hot spots and insulating them. Paying close attention to the front and rear cap and firewall. So much heat is allowed into the MH's that even 3 15000's would struggle to cool things. The engineer was interested in exploring that.
Hopefully they can make the new models more energy efficient.
08-15-2015, 05:59 PM
The Berkshires have two 13500 btu ac units. At 115° it's no help. Interior temps in the mid 90°s.
Paul
08-15-2015, 07:00 PM
Phat Phrog Stunt Crew
Sounds like it's a little warm in Phoenix. I guess we'll wait a few weeks or so before we go back to Casa Grande.
2014 Wildcat 327ck
08-15-2015, 08:34 PM
U.S. But it's a dry heat! Not!
Jc
2014 400BH-60
08-15-2015, 08:52 PM
Water can cause issues with the fins on the AC unit. The scale inhard water could create deposits and reduce efficiency long term. I did this as last chance once on a failing wallmount AC unit, it was in need of replacement and did get use through a tough spot.
B and B
08-16-2015, 12:06 PM
Paul
Using a water spray and painting the hoods white, SHOULD make an incredible difference. But not being an AC expert, I could be completely wrong
Boowho?
08-19-2015, 02:02 PM
Sounds like the answer is to avoid AZ summers
2012 Forest River Berkshire 390FL
2013 Hyundai Veloster
08-19-2015, 02:22 PM
I just painted my hoods white but haven't had a chance to test them yet.
2011 Berkshire 390-rb-40, upgraded tires and front axle airbags, 2012 Jeep Wrangler 2 door, Blue Ox baseplate and BlueOx aladdin tow bar, Blue Ox Patriot brake system, wiring run through right frame rail and homemade led taillight bar.FB.
Ham KG5LTL.
08-19-2015, 02:25 PM
YEP, AZ summers suck!! But oh the January weather in Yuma!!!
boowho??
08-19-2015, 06:06 PM
They try to sell that misting system for our air-conditioners here in Arizona but I don't think I'd put corrosive water anywhere near my vehicle if I could avoid it... If you do the pressure of the pump is very critical low-pressure you're going to get water droplets very high-pressure like 300 or 1000 PSI pump for your misting system you'll get vaporized water it's very critical to get the vaporized water for the best cooling... I do have misters around my awning and pop up.
Jc
2014 400BH-60
08-19-2015, 08:09 PM
You're spot on. Never doing that again.
Paul
