06-10-2015, 12:57 PM
Water Filter Rart Number
I have a 2011 390BH and i am looking to replace my fresh water filter that is located in the water bay. I keep forgetting to look for a part number when i am over at the storage lot. could someone help me out with the filter part number and were i could purchase a replacement filter.
06-10-2015, 01:40 PM
These pics should help.
Jason
06-10-2015, 03:07 PM
Here is the filter info frpm Forest River
06-10-2015, 06:09 PM
On a 2011 it should take just a cheap filter from Lowe's or HD. You can choose the mic size I think I have 5 micron but the filters are a standard filter. The new Berkshire have a more expensive filter and are harder to find.
06-11-2015, 12:02 PM
If that's the one you have, & it's cheap, then you are lucky, my Forested takes a CCI-10-CA, normally $32. I have found them as cheap as $28.😥
06-11-2015, 12:06 PM
This is what I use.
06-11-2015, 12:10 PM
The filter in the canister is two weeks old. We have lots of iron in the water. I use two filters. One before the water softener and the one for the whole house coach. I'm very happy with the setup and don't know why they went to that expensive filter setup.
06-11-2015, 12:20 PM
It depends on your water fiter. If you have a KW-1, these are only available from Forest River, either from the factory, or some Forest River dealers stock them. Mine does.
Good luck.
06-11-2015, 12:29 PM
I think the 2012 and newer use the expensive filter.
06-11-2015, 12:56 PM
my 2010 Georgetown uses and came with the expensive water pur filter. will the hdx work for mine also?
06-11-2015, 01:27 PM
My Water Pur filter takes the same cartridge as the Camco EVO filter. Wally World stupidly stacks the filter assembly, but not the replacement cartridge. But you can order the cart. from their O/L site for delivery to the store.
Camco EVO Spun PP Replacement Cartridge - Walmart.com
06-11-2015, 02:24 PM
I don't think so. Georgetown must have gone to that filter earlier. I don't see an advantage to it. Is it that much better system? I can get as aggressive filter as I want and they are cheap.
06-11-2015, 03:52 PM
I think I got them from Amazon. This filter is Made for forest river from what I understand.
06-12-2015, 07:45 AM
I have been looking on-line @ Wal-Mart for a replacement for my CCI-010-CA,,,
I may have found a couple that might work,,, I will take an old one with me one of these days & check them out,,, I am looking @ Camco EVO Replacement Cartridge,,, @ $11.10,,, and 3M Filtrete Whole House Carbon 2 pk @ $9.33 ???
Thanks CCONDOS for the INFO !!!
06-12-2015, 07:52 AM
I have been told there is a By-pass plug you can buy for the water filter sys,,,
but I have not been able to find it on-line anywhere ??? I would LOVE to be able to remove Canister in the Winter !!! What ever you do,,,
DO NOT let one freeze & brake !!!
06-12-2015, 08:45 AM
I never even put the filter in since we do not drink the water and in the winter just unscrew the canister and empty it and it should never freeze on you.
Jason
06-12-2015, 05:54 PM
Jason
X-2. No filters.
Russell
06-14-2015, 07:27 AM
X2 - maybe to no-filters. Heard horror story at one campground where the had a water pipe break. After their repair, all kinds of sludge got into the lines of campers and extended stay residents.
Yes, removing filter gives better flow rates, but besides the water pipe problem, I am not sure what is in the campground water supply. That's why most do not drink it. Not sure that I want the MH to not be protected.
Gale & Hank- 2012 Berkshire 390BH
06-14-2015, 07:48 AM
I am guessing that people that use campground water would be using a in-line filter on there hoses ??? I use a filter here @ home when filling fresh water tank with soft water from our well !!!
06-14-2015, 03:42 PM
Anacortesians
Well at least the mis-spelled "Part" in the title was with an "R" and not an "F".
Frank and Eileen
No longer RVers or FR owners
