Old 06-10-2015, 12:57 PM   #1
Water Filter Rart Number
I have a 2011 390BH and i am looking to replace my fresh water filter that is located in the water bay. I keep forgetting to look for a part number when i am over at the storage lot. could someone help me out with the filter part number and were i could purchase a replacement filter.
csichoice is offline   Reply With Quote
Old 06-10-2015, 01:40 PM   #2
JTN8's Avatar
These pics should help.
Name:	ImageUploadedByForest River Forums1433961599.918669.jpg
ID:	79571Click image for larger version
Name:	ImageUploadedByForest River Forums1433961611.089744.jpg
ID:	79572Click image for larger version
Name:	ImageUploadedByForest River Forums1433961623.981016.jpg
Jason
Old 06-10-2015, 03:07 PM   #3
Mmnsc's Avatar
Here is the filter info frpm Forest RiverClick image for larger version
Name:	ImageUploadedByForest River Forums1433966844.464814.jpg
Mmnsc is offline   Reply With Quote
Old 06-10-2015, 06:09 PM   #4
On a 2011 it should take just a cheap filter from Lowe's or HD. You can choose the mic size I think I have 5 micron but the filters are a standard filter. The new Berkshire have a more expensive filter and are harder to find.
Old 06-11-2015, 12:02 PM   #5
If that's the one you have, & it's cheap, then you are lucky, my Forested takes a CCI-10-CA, normally $32. I have found them as cheap as $28.😥
bukhrn is offline   Reply With Quote
Old 06-11-2015, 12:06 PM   #6
This is what I use. Click image for larger version
Name:	ImageUploadedByForest River Forums1434042366.796402.jpg
ID:	79634Click image for larger version
Name:	ImageUploadedByForest River Forums1434042401.897309.jpg
Old 06-11-2015, 12:10 PM   #7
The filter in the canister is two weeks old. We have lots of iron in the water. I use two filters. One before the water softener and the one for the whole house coach. I'm very happy with the setup and don't know why they went to that expensive filter setup.
Old 06-11-2015, 12:20 PM   #8
It depends on your water fiter. If you have a KW-1, these are only available from Forest River, either from the factory, or some Forest River dealers stock them. Mine does.
Good luck.
tomrob1161 is offline   Reply With Quote
Old 06-11-2015, 12:29 PM   #9
I think the 2012 and newer use the expensive filter.
Old 06-11-2015, 12:56 PM   #10
my 2010 Georgetown uses and came with the expensive water pur filter. will the hdx work for mine also?
DAPYES is offline   Reply With Quote
Old 06-11-2015, 01:27 PM   #11
Chuck.C's Avatar
My Water Pur filter takes the same cartridge as the Camco EVO filter. Wally World stupidly stacks the filter assembly, but not the replacement cartridge. But you can order the cart. from their O/L site for delivery to the store.
Camco EVO Spun PP Replacement Cartridge - Walmart.com
Chuck.C is offline   Reply With Quote
Old 06-11-2015, 02:24 PM   #12
I don't think so. Georgetown must have gone to that filter earlier. I don't see an advantage to it. Is it that much better system? I can get as aggressive filter as I want and they are cheap.
Old 06-11-2015, 03:52 PM   #13
I think I got them from Amazon. This filter is Made for forest river from what I understand.
Mr. Mike 45 is offline   Reply With Quote
Old 06-12-2015, 07:45 AM   #14
Wolverine 1945's Avatar
I have been looking on-line @ Wal-Mart for a replacement for my CCI-010-CA,,,
I may have found a couple that might work,,, I will take an old one with me one of these days & check them out,,, I am looking @ Camco EVO Replacement Cartridge,,, @ $11.10,,, and 3M Filtrete Whole House Carbon 2 pk @ $9.33 ???
Thanks CCONDOS for the INFO !!!
Wolverine 1945 is offline   Reply With Quote
Old 06-12-2015, 07:52 AM   #15
I have been told there is a By-pass plug you can buy for the water filter sys,,,
but I have not been able to find it on-line anywhere ??? I would LOVE to be able to remove Canister in the Winter !!! What ever you do,,,
DO NOT let one freeze & brake !!!
Old 06-12-2015, 08:45 AM   #16
JTN8's Avatar
I never even put the filter in since we do not drink the water and in the winter just unscrew the canister and empty it and it should never freeze on you.
Jason
Old 06-12-2015, 05:54 PM   #17
CAT-RN's Avatar
Jason
X-2. No filters.
Russell
CAT-RN is offline   Reply With Quote
Old 06-14-2015, 07:27 AM   #18
I-RV's Avatar
X2 - maybe to no-filters. Heard horror story at one campground where the had a water pipe break. After their repair, all kinds of sludge got into the lines of campers and extended stay residents.
Yes, removing filter gives better flow rates, but besides the water pipe problem, I am not sure what is in the campground water supply. That's why most do not drink it. Not sure that I want the MH to not be protected.
Gale & Hank- 2012 Berkshire 390BH
I-RV is offline   Reply With Quote
Old 06-14-2015, 07:48 AM   #19
I am guessing that people that use campground water would be using a in-line filter on there hoses ??? I use a filter here @ home when filling fresh water tank with soft water from our well !!!
Old 06-14-2015, 03:42 PM   #20
Anacortesians
Well at least the mis-spelled "Part" in the title was with an "R" and not an "F".
Frank and Eileen
No longer RVers or FR owners
water, water filter
