Old 06-10-2015, 12:57 PM   #1
Water Filter Rart Number
I have a 2011 390BH and i am looking to replace my fresh water filter that is located in the water bay. I keep forgetting to look for a part number when i am over at the storage lot. could someone help me out with the filter part number and were i could purchase a replacement filter.
csichoice is offline   Reply With Quote
Old 06-10-2015, 01:40 PM   #2
JTN8's Avatar
These pics should help.
Name:	ImageUploadedByForest River Forums1433961599.918669.jpg
ID:	79571Click image for larger version
Name:	ImageUploadedByForest River Forums1433961611.089744.jpg
ID:	79572Click image for larger version
Name:	ImageUploadedByForest River Forums1433961623.981016.jpg
Jason
Old 06-10-2015, 03:07 PM   #3
Mmnsc's Avatar
Here is the filter info frpm Forest RiverClick image for larger version
Name:	ImageUploadedByForest River Forums1433966844.464814.jpg
Mmnsc is offline   Reply With Quote
Old 06-10-2015, 06:09 PM   #4
On a 2011 it should take just a cheap filter from Lowe's or HD. You can choose the mic size I think I have 5 micron but the filters are a standard filter. The new Berkshire have a more expensive filter and are harder to find.
Old 06-11-2015, 12:02 PM   #5
If that's the one you have, & it's cheap, then you are lucky, my Forested takes a CCI-10-CA, normally $32. I have found them as cheap as $28.😥
bukhrn is offline   Reply With Quote
Old 06-11-2015, 12:06 PM   #6
This is what I use. Click image for larger version
Name:	ImageUploadedByForest River Forums1434042366.796402.jpg
ID:	79634Click image for larger version
Name:	ImageUploadedByForest River Forums1434042401.897309.jpg
Old 06-11-2015, 12:10 PM   #7
The filter in the canister is two weeks old. We have lots of iron in the water. I use two filters. One before the water softener and the one for the whole house coach. I'm very happy with the setup and don't know why they went to that expensive filter setup.
Old 06-11-2015, 12:20 PM   #8
It depends on your water fiter. If you have a KW-1, these are only available from Forest River, either from the factory, or some Forest River dealers stock them. Mine does.
Good luck.
tomrob1161 is offline   Reply With Quote
Old 06-11-2015, 12:29 PM   #9
I think the 2012 and newer use the expensive filter.
Old 06-11-2015, 12:56 PM   #10
my 2010 Georgetown uses and came with the expensive water pur filter. will the hdx work for mine also?
DAPYES is offline   Reply With Quote
water, water filter
