Old 05-21-2014, 03:25 PM   #11
2011 Berkshire 390BH
Superchief's Avatar
Just changed out my electric element on my suburban water heater. Not a difficult job after reading some posts on here and watching a You Tube Video on how to do it and also test out the element. Here is a picture of the element: Click image for larger version
Name:	ImageUploadedByForest River Forums1400703205.429459.jpg
ID:	52950. You can see where it failed. I got the tool to take it out from Lowes, in the appliance section. I also picked up a 1500W/120V universal element for $8.70. The wrench was $6.54. Not bad! Took the element out and found that the one in there was a 1440W/120V. Click image for larger version
Name:	ImageUploadedByForest River Forums1400703507.390609.jpg
ID:	52951Click image for larger version
Name:	ImageUploadedByForest River Forums1400703538.449009.jpg
ID:	52952 Not being sure how to proceed, I went to the local RV Dealer and picked up a 1440W/120V Suburban Electric Element - cost $30.86 - 3 times plus the cost of the one at Lowes. To save someone else who maybe replacing there element in the future, should I have gone ahead and used the cheaper element, or replaced it with the one it was designed for, which is what I did? Thanks for your input! Craig
Craig
Finally completed all State visits in August 2011 with a trip to North Dakota.
Superchief is offline   Reply With Quote
Old 05-21-2014, 03:31 PM   #12
tmmar's Avatar
Craig,
I used the 1500 w element. I thought that the slightly higher watts of the element would help heat the water quicker. It worked just fine.
Tom
Tom and Margaret
2014 Berkshire 390bh-60
Old 05-21-2014, 08:38 PM   #13
Superchief's Avatar
I should add a note of caution if anyone is planning on installing a new electric element in their hot water heater. The element is relatively easy to replace. The problem I ran into which I did not expect was after I drained the hot water tank, I found water on my kitchen floor. It had been raining and I was under the awning working. When I put the awning in, there was a considerable amount of water that came down the side of the coach, so I figured that to be the source. More water appeared. After investigating I found the water was coming from the bottom area under the hot water tank. Thinking I might have knocked something loose trying to get the element out, I checked all the fitting, etc., not the source. I finally figured out that the caulking on the outside, inside the hot water door, bottom area had been compromised and was letting the water that was draining out of the tank flow under the tank (I hope that makes sense - if you take off the cover door to the hot water tank, you will see caulking on the bottom of the little shelf there). So the caution is to ensure that there is a caulking seal on the bottom lip. Hope that is not too confusing. Craig
Craig
Old 05-21-2014, 09:43 PM   #14
Same thing happened to me when I replaced mine last summer. Water all over the kitchen floor.
I removed the old element, stuck a broom stick in the hole to see how long of a replacement element I could install.
AFAIK, that is the only thing to worry about; just make sure the length is no more than will fit in the tank; maybe stand an inch or so off the back wall of the heater. More wattage will just heat the water quicker.
Plus make sure the one you buy is for 110V. Many (most?) of them are for 220V (again, AFAIK)
Boowho??
boowho is offline   Reply With Quote
Old 05-21-2014, 10:03 PM   #15
wmtire's Avatar
I don't think you would have any problems with a 1500 watt element...... but....You don't want to go TOO much larger wattage (if they make such a monster), because of the wiring and amps.
The stock electric heating element is 1440 watts, because that is the max amps the 14 gauge wire used in them is SAFELY rated for.
Remember that watts = voltage X amps ...or 1440 watts = 120 volts X 12 amps.
Higher wattage draws more amps thru the wire.
Here is the attorney tags from Suburban for the element/wire.... and the wire.
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 05-21-2014, 10:09 PM   #16
You are right...... my bad.
Boowho??
Old 05-21-2014, 10:19 PM   #17
Superchief's Avatar
That may explain why the circuit breaker is a 15 amp breaker on the hot water system in my unit. If I did my math correctly, a 1500W/120V element would draw 12.5 amps, where by a 1440W/120V element would draw 12.0 amps, as you noted.
Craig
Old 05-21-2014, 10:27 PM   #18
wmtire's Avatar
Correct....... but the amps can change with fluctuating voltage in reactive loads (like motors, pumps, a/c, etc). Electrical wiring has a built-in safety margin at 80%.
EDIT: I forgot a heater element is a resistive load and thus the watts will drop when the voltage drops. Editing post to take out erroneous info.
When you are at campgrounds that have less than optimal 120 volts (say 110 volts), then your electric heating element will take longer to heat as it will have less watts.
I don't really think anyone should overload with using a 1500 watt element. If they do make higher wattage elements than that (I haven't checked), then you may run into problems.
Just pointing out the math.
Old 05-21-2014, 10:33 PM   #19
Superchief's Avatar
And thus 80% of 15 amps is 12.0 amps - Thanks
Craig
Old 05-21-2014, 10:42 PM   #20
wmtire's Avatar
You're welcome..... and I am envious of your visited states map.
heater, water, water heater
