Old 06-06-2014, 12:23 PM   #1
Water Heater Electrical Issue
I have a 2010 Berkshire with a Suburban SW10DE water heater. When I run the water heater on electric it draws my current very low. With the water heater off I have 119-122 volts coming into the coach. When I turn the electric water heater on the voltage drops to 110-112 volts. Anyone have any ideas how to correct this issue? Has only recently become a problem.
RNuzzolo is offline   Reply With Quote
Old 06-06-2014, 01:25 PM   #2
tmmar's Avatar
RN,
The water heater is a big current draw when used in the electric mode. I know this because I didn't turn it off one day when we finished camping and I began to travel and was using the generator to power both air conditioners on a hot day. The circuit breaker on the generator tripped and I didn't know why since I had been running both AC's without a problem earlier. Turned off the water heater and the problem went away. It is a real power hog when on electric. Just turn it off when not needed.
Tom
Tom and Margaret
2014 Berkshire 390bh-60
Old 06-06-2014, 02:20 PM   #3
Campin Cajun's Avatar
I would have to agree and say that is pretty normal. No science behind my opinion other than the two fivers I owned had that type of water heater and when it kicked on it would trip other breakers in the campers.
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
electric, electrical, heater, water, water heater
