Old 05-18-2014, 10:09 PM   #1
DJP6371's Avatar
Water Heater Temperature problem
Was dry camping this past week. Fired up the water heater on propane and I could hear it fire up and heat from the outside of the RV. When using the water over the next couple of days, I notice that the water was warm, but not hot.
Someone suggested that I may not de-winterized properly and utilized the by-pass.
Not sure if that's the problem, but I have attached a couple of pix of the by-pass. Is it in the right position? and would this be the cause of low water temperature?
DJP6371 is offline   Reply With Quote
Old 05-18-2014, 10:12 PM   #2
Broadway Joe's Avatar
The center (bypass) valve should be in the closed position.
Broadway Joe is offline   Reply With Quote
Old 05-18-2014, 10:13 PM   #3
Rrickim63's Avatar
I think you want to turn the middle one to block the flow.
1999 Silverado with tow package
2006 Roo 23B hybrid
2006 Roo 23B hybrid
2006 Ford F150 4.6L
Rrickim63 is offline   Reply With Quote
Old 05-18-2014, 10:42 PM   #4
Berkshire 390QS
NO3putt's Avatar
They said it all, turn the middle knob to close.
NO3putt is offline   Reply With Quote
Old 05-18-2014, 10:43 PM   #5
2011 Berkshire 390BH
Superchief's Avatar
X4
Craig
Finally completed all State visits in August 2011 with a trip to North Dakota.
Superchief is offline   Reply With Quote
heater, water, water heater
