Old 08-04-2013, 03:59 PM   #11
klucas's Avatar
Originally Posted by boowho View Post
In visiting the factory, I got the impression that each worker did things the way HE wanted to do it; in other words there was no "official" checklist or inspection done until the very end.
Therefore if worker A filled the cracks on coach ONE and worker B filled the cracks on coach TWO, there was no guarantee that they would be done the same. Same if you were having a "sticks and bricks" house built by a contractor.
I'd guess you were just unlucky enough to get a worker that wasn't quite as conscientious as he could have been or hell, maybe his can of foam just went empty!!
Boowho??
Boowho. How do you like the tire /airbag upgrade? Got mine done last week and haven't driven it much yet. What's your thoughts.
klucas is offline   Reply With Quote
Old 08-04-2013, 06:44 PM   #12
2011 Berkshire 390BH-60
TaterColo's Avatar
On my coach they foamed some gaps but not others. I think I got worker B that ran out of foam and said "screw it - it's almost quitting time and my buds are already at the bar".
TaterColo is offline   Reply With Quote
Old 08-05-2013, 12:16 PM   #13
Well, it's better than nothing, but I'm still either very close to, or actually overweight in the back. I did gain 1500 lbs on the front axle which is very good. I'm going to run it over a CAT scale as soon as I move it again (This coming Saturday).
The coach drives no differently, but I was VERY happy with the way it handled before the upgrade. It MAY ride just a tiny bit better.
I gained three years on my tire life, but it cost me about $800 in diesel to get to Elkhart. I wouldn't have gone that way if I hadn't needed to do so. I rarely get East of the Rockies.
My wheel covers fit a LOT better (side benefit), but they forgot to re-program the FL computer for the larger tires. So now my odometer, speedometer, etc are off by about 5% (in my favor). I will get this taken care of next time I'm near a FL dealer.
How about your thoughts???
Boowho??
boowho is offline   Reply With Quote
Old 08-05-2013, 12:18 PM   #14
HA!!! So true with a lot of workers these days
Boowho??
Old 08-05-2013, 08:35 PM   #15
klucas's Avatar
Boowho??
Seems like a difference in handling. Less body roll on corners and less feel of impact on road bumps ect. They sure do fill out the wheel wells a bunch. Another side note it raised the ride height a bit so my rear mud flap sits a bit higher. Now it doesn't rub as much. So far I'm pleased with the change.
