Old 06-04-2016, 08:06 PM   #1
Himcules's Avatar
water manifold part numbers
hello all.. been awhile...
anyways, i had a little issue with freezing water over the winter and my water filter canister and the water manifold cracked. so i searched and searched and apparently no one had posted the part numbers yet.
i just found them so if you are in need, they are here:
Flair-It Plus 4 port manifold - part number: 07901 (similar part is 17901)
Flair-It Plus 2 port manifold - part number: 07900 (similar part is 17900)
Flair-It Plus manifold male swivel coupler - part number: 17921
Flair-It Plus manifold bracket pair - part number: 07922
Flair-It Red valve 1/2" x 1/2" - part number: 07891
Flair-It Blue valve 1/2" x 1/2" - part number: 07890
Flair-It 1/2" caps for unused ports - part number: 07918 (you can use home depot 1/2" caps)
some parts avail on amazon. other parts at www mobilemart dot com and a few other places.
at the time of this post, the WaterPur FR1 water filter has been replaced by something else so I can't get a new plastic canister. so i opted to just by-pass it with some 1/2" threaded fittings from Home Depot. i reused the 2 threaded 90 deg elbows. just got 2 1/2" female threaded couplers and a 1/2" threaded connector pipe to make up the space perfectly. I'll just rely on the external water filters now.
hope this info helps...
himcules (10x stronger than hercules)
2013 Forest River Berkshire 390BH-60
ex 2007 Jayco Greyhawk 31SS
Himcules is offline   Reply With Quote
water
