Old 04-11-2016, 08:10 PM   #11
Dbt803's Avatar
I have the dometic 4 door that runs on propane or electric
Debbie
"Midnight Pearl" - 2011 Berkshire 390 BH
Dbt803 is offline   Reply With Quote
Old 04-11-2016, 09:53 PM   #12
Berkshire 390QS
NO3putt's Avatar
On our dometic, water shut off under bathroom sink, solnoid is reached from outside hatch with clear water line going to it.
Old 04-12-2016, 06:33 AM   #13
CAT-RN's Avatar
Water on floor under fridge
Don't know how yours if but in my water compartment I have a shut off for the ice maker. We never use the ice maker so I shut it off. Then just above the shut I disconnect the line going to the ice maker. Thus allowing any water in the line to drain back. Also easy to know that it is shut off good. I have a 2014. 390 FL
Russell
CAT-RN is offline   Reply With Quote
Old 04-12-2016, 07:59 AM   #14
tmmar's Avatar
I think when a 'residential' refrigerator is being discussed, that it must be clearly stated that it is either a Dometic or a Whirlpool. When the refrigerator is described as a 'residential refrigerator', clearly there is a big difference between the two and they have nothing in common.
Tom and Margaret
2014 Berkshire 390bh-60
tmmar is online now   Reply With Quote
Old 04-12-2016, 08:50 AM   #15
Dbt803's Avatar
Mine is not residential. I shut off the cold water to the bathroom sink in the outside water compartment until I can get it fixed.
Debbie
Old 04-12-2016, 11:51 AM   #16
Vince and Charlette's Avatar
Last year, I had the identical problem with my Frigidaire residential sized refer. To my amazement, it was the internal removable filter inside the fresh food compartment! I didn't think to drain it during winterization. You guessed it - During the winter, the water inside froze and it split the sides of the filter wide open. A day or so after hooking up to city water in the Spring, I noticed water running from under the refer. The filter was leaking steadily! I hope this helps.
2018 Berkshire 38A
Vince and Charlette is offline   Reply With Quote
Old 04-12-2016, 11:59 AM   #17
mike.t's Avatar
Condensation drain plugged/frozen?
2015 Salem 27RKSS
2015 Ram 2500 CC 4x4 Cummins
55' Chevy Bel-Air
Burgers on the BBQ and a cold beer
mike.t is offline   Reply With Quote
Old 04-12-2016, 12:07 PM   #18
Home2Roam
Home2Roam's Avatar
Send a message via MSN to Home2Roam Send a message via Skype™ to Home2Roam
RE: Water on floor under fridge.
I just had to give our unfortunate story here. We had the same problem in our Charleston. We saw water dripping under the slide that holds the refrigerator. I took it in for repair and was told it was the overflow from defrosting the fridge, I let it go until a day or so later when I realized we had never defrosted the fridge. The unit was new. So I made another appt but a roaming repair guy came through the park and fixed it for me. It was two tiny leaks where someone had put brass fittings on the plastic water hose and they cut right through the hose. It took so long to find and fix the problem that we have quite a bit of water damage now in that slide.
Please tell me the factory does not install brass fittings on plastic hoses...anyone?
Home2Roam is offline   Reply With Quote
Old 04-12-2016, 03:44 PM   #19
BobbyJ
Bobbyj's Avatar
I too never used mine, but still paid dearly. These babies are difficult to winterize with ice-makers. I paid the price with water everywhere too. Finally, after the 8 hour repair. Had to remove the washer and dryer to get to the back of the fridge and the wall enclosure was put on after they installed the appliances, so I had to tear that out too. I better stop here, because it was actually a lot worse than that and it was a day to forget. Back on point here. To winterize the ice maker I hooked up the air line and allowed the fridge to try to make ice. When if tries to make ice (send an electrical signal to the solenoid) the air will push the water up the tube into the ice maker. Keep this going for 12 hours. You will get some tiny ice cubes. No where in FR's videos etc. do they mention this. The solenoid is at the base of the fridge as stated and will fill with water from the long tube to the ice maker. It will have water in the tube/solenoid valve body even if you did not use the ice maker, then it breaks at around 25 deg. F. The solenoids are fairly cheap and easy to repair, however. That is if it is easily accessible.
Best regards,
BobbyJ
State College Pa.
Bobbyj is offline   Reply With Quote
Old 04-12-2016, 09:21 PM   #20
Disconnect the water supply to your ice maker. It should be located under your kitchen sink. You may have a pinhole leak in the supply tubing. Good luck.
MrLucky is offline   Reply With Quote
fridge, water
