Old 04-28-2014, 11:42 PM   #1
2011 Berkshire 390BH-60
TaterColo's Avatar
Water pressure.
I have no water pressure with the water filter in. I take the filter out an all is good. I even drilled the hole bigger in the filter and still no pressure. Do I need a new pump?
TaterColo is offline   Reply With Quote
Old 04-29-2014, 02:17 AM   #2
Do you have the same issue when connected to city water? I have a problem when the filter is in both ways. So far I either run with the biggest micron filter it that works or I just remove it.
Old 05-04-2014, 12:42 AM   #3
Joker's Avatar
That's kinda odd guys. I've never had problems with the filter. Maybe you have one that isn't quite the right size?
Joker is offline   Reply With Quote
Old 05-04-2014, 01:14 AM   #4
Berkshire 390QS
NO3putt's Avatar
Where did you get your filters? I've been getting mine at lowes, you can find two filters that look the same, length etc, but noticed some have only a small hole at either end and others have a large openings. You didn't by chance pick some up with the small opening? Was half way out of store when I looked down and saw only a small hole and went back to get the other ones.
2015: 188 days, 2016: 72 days, 2017: 185 days: 2018 182 days
2019: 156 days (2009 Berkshire, 390QS, and toad)
Old 05-04-2014, 10:16 AM   #5
Joker's Avatar
Here's what my package looks like, bought from CW, about $10Click image for larger version
Name:	ImageUploadedByForest River Forums1399216570.884608.jpg
Old 05-04-2014, 10:51 AM   #6
Berkshire 390QS
NO3putt's Avatar
water filyer
The filter we use have a large opening, some filters have what looks like a plug inside the opening and that may reduce water flow. Would guess if your presure/water flow is good with filter out then you might have picked up a filter with a plug inside.
Old 05-04-2014, 02:32 PM   #7
dan-nickie's Avatar
Are you guys talking about the KW1 / FR1 type filters?
Sent from my DROID BIONIC using Forest River Forums mobile app
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 05-04-2014, 03:22 PM   #8
tmmar's Avatar
dan,
The OP has a 2011 Berkshire. Not sure when they went to the new FR1 filter cartridge but I had an '08 and it had a more generic, whole house (stick and brick) filter that used cartridges that I could get at Lowes. The new cartridge is proprietary to Forest River and you can only get replacement cartridges from them.
Tom
Tom and Margaret
2014 Berkshire 390bh-60
pressure, water
