Old 07-26-2010, 01:49 PM   #11
tmmar's Avatar
Pump should be on the passenger side in a compartment just in front of the rear wheels. There are 2 spring pins that are on the under side of the door that need to be pulled then you can open the 2 latches. Pump is on the lower left in the compartment.
Tom and Margaret
2014 Berkshire 390bh-60
Old 07-27-2010, 05:41 PM   #12
Originally Posted by brevin66 View Post
Also, Air bags will not inflate if jacks aren't fully retracted. We've had to cycle them a couple times to make sure. It's pretty simple to figure out if the bags don't inflate, I promise there is nothing quite like it. There must be a trigger switch when they are fully up and if just 1 isn't, you just sit there with flat bags. I offer this because I was about 15 minutes away from a big tow when I cycled the jacks again and the problem corrected.
I experienced this situation also. It's not that the jacks aren't fully retracted, the problem lies in the sequence of events that you use when retracting the jacks. When the jacks are extended the dump valve (air) opens, which in turn releases all air pressure. Air pressure has to be above 75 psi before retracting the jacks.
Since I have followed this sequence I haven't had the problem rise again.
1) Start coach and let the air pressure build above 75 psi.
2) Retract jacks.
3) You are ready to roll.
Take care.
2008 Forest River Berkshire 390QS
2006 Ford Focus Toad
Sometimes 6X12 enclosed trailer with a
2007 1200c HD Sportster & a 2006
HD Night Train
06nighttrain is offline   Reply With Quote
Old 07-28-2010, 09:03 AM   #13
On the Jack issue, get in the habit of starting the unit and letting the air bags fill up after you run the rooms in prior to leaving. Then you can continue to pack up the rig. Doing this will allow the bags to fill and the tank to fill, then when you hit all retract you will be sure to have air in the system to operate the jacks...Equalizer now recommends this procedure.
amy8194 is offline   Reply With Quote
Old 07-28-2010, 11:54 AM   #14
CLASS "A" Senior Member
cfsoistman's Avatar
Originally Posted by NWJeeper View Post
There also should be a sediment filter right at the output of the pump. Check to see if maybe debris from initial construction may be clogging that and clean it.
Sediment filter screen is installed before the pump. It keeps any crude from entering the pump and causing damage. I know I forgot to remove it when winterizing and dump the little remaining water prior to blowing out the lines. It froze, cracked and wouldn't allow the pump to draw water from the tank when I filled the tank in the spring. They don't sell just the cap for the screen just the whole assembly for about $11-$12. I wrote on the black cover to the pump compartment in Silver Sharpee a winterizing reminder to myself to dump the water. I did pick up a spare at Camping World in Myrtle Beach for $5 on a clearance table in case I don't follow my own directions.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
cfsoistman is online now   Reply With Quote
Old 07-29-2010, 02:42 PM   #15
2011 Berkshire 390bh
wnytaxman's Avatar
We also have experienced the low pressure in the kitchen, but only in the kitchen. I'll check out the sediment screen tonight and see if that is a problem. We've not experienced a problem with the air bags at all since we got our Berkshire. We just wait until the pressure builds up past 75 psi and then we go. Haven't had the other issues yet.
wnytaxman is offline   Reply With Quote
Old 10-28-2010, 04:38 PM   #16
amarzano's Avatar
We had an issue with the bags not filling on our trip last weekend.
We had set up on a Friday - extended the jacks. Before I retracted them on Sunday - I played with the manual adjustments (it was pouring rain and I was trying to tilt the coach and get some of the water off the slide topers before pulling in the slides) - the ride felt a lot bumpier than it did when we drove in.. :-)
I got about 2 blocks thru the campground and then extended the levelers again - and retracted them. The bags then filled up and we were fine.
Are you suggesting starting the motor letting the air pressure build to 75psi, then shutting off the motor and retracting? On ours - both the jacks and slides can only be used when the key is out of the ignition..
Thank you..
2) Retract jacks.
Take care.
2011 Berkshire 390BH-60
Cummins ISB 360hp/800ft-lbs DEF
Allison 3000
amarzano is offline   Reply With Quote
Old 10-29-2010, 11:08 PM   #17
Yes that will work also, but you should be able to retract the jacks with the engine running. The interlock will not let you deploy the jacks or operate slide outs with the engine running. I have a "08" & that's how mine operates, not sure if that has changed on the newer models. Try it & let me know.
Take care.
HD Night Train
Old 10-30-2010, 08:01 AM   #18
I carry a water pressure test gauge to check campground water pressure. If its not over 50 PSI I don't use a regulator. Its available at the Home Depot for less tham $10. Very seldom use a regulator.
Bill And Theresa Perry, At Lake Gaston
2004 R Vision Trail Lite
2003 F 150 Super crew with 5.4 Tow package
bill and theresa is offline   Reply With Quote
Old 10-30-2010, 02:28 PM   #19
amarzano's Avatar
I see - the interlock is only on deploying and extending the slides and levelers..
I will try this the next time we are out and post back.
Thank you!
Alex
Take care.
Allison 3000
air bags, berkshire
