10-16-2014, 03:30 PM
marialee-Berkshire410qs
Water pump
Needed to use water pump..turned on pump. No water. Turned pump off and on had water. Turned off pump. Later Turned on pump no water. What do you think guys.
10-16-2014, 03:36 PM
Are you hooked up to city water?
Is your fw tank full?
Your description is pretty vague.
Turbs
10-16-2014, 03:38 PM
following
2012 F-350 4x4 King Ranch Super Duty CC 6.7 Turbo Diesel 3.55 e-locker
2011 Palomino Puma 30KFBDS with Side Paw Kitchen and Bunkhouse
Equalizer E2 Hitch
How much water in your FW tank?
Did you hear the pump come on when you turned the switch on?
2013 Berkshire 390BH
10-16-2014, 04:00 PM
Not hooked up to city water. Yes have plenty of water in FW tank. No pump not coming on. Lights indicating tank on work. Checked wiring at pump it looks good. Going to check connection in control panel on wall in coach. We may need new pump. ;(.
10-16-2014, 04:01 PM
Lights indicating the water pump switch is on works.
10-16-2014, 04:02 PM
It just doesn't make sense that you get water with pump off but don't get water with pump on?
I'm assuming it's worked fine until now?
There is a fuse several inches from the pump or should be.
Turbs
10-16-2014, 04:06 PM
Check both switches, not sure if that will matter but it's worth a try.
And please clarify that you get water without the pump coming on???
10-16-2014, 04:08 PM
Sorry. We don't get water with pump on or off. Will check for fuse at base of pump. 2011 Berkshire410QS.
10-16-2014, 04:09 PM
Do you have any idea where fuse at base would be? It the original pump still.
10-16-2014, 04:10 PM
Not sure if you have one on there or not, but there might be a filter between the tank and the pump that could have some trash in it.
10-16-2014, 04:14 PM
Thanks so much will check that also!!
10-16-2014, 04:17 PM
I had a similar problem that turned out to be a bad connection on the switch located in the wet bay. Cleaned up the contacts and all was well.
RKC02
2014 390RB-60 "The Shire"
10-16-2014, 05:18 PM
Pump could be in bypass for winterization. Pump is used to pump in rv antifreeze. Did not see if it was mentioned, you should here the pump running if is working.
2020 Georgetown 31L, Safe T steering, Sumo springs, Onan Geny
2015 GMC Canyon 4X4 TOAD w/Blue Ox tow plates, InvisiBrake
Pepper 🌶 PomChi rescue 545 nights as our camping buddy
Days camped in FR 2011-12 = 77, 13-14 = 98, 15-16 = 129
17 = 81, 18 = 44, 19 = 83, 20= 45, 21 = 76, 22 = 57, 23 = 42
Retired :
10-16-2014, 05:36 PM
Not in bypass for winterization. We have been on the road since July. Thanks
10-16-2014, 06:57 PM
Do you have a multimeter or 12v test light?
If you don't you should get one to keep in the camper.
Your going to need it time and time again.
You need to check for power at the pump with switch on.
the wire coming out of the pump should be about 8 to 10 inches long then a butt connector.
Check there.
Power there ? Pump bad.
No power? Bad switch or wire.
Turbs
10-16-2014, 07:30 PM
I would hit the pump. It is possible the pressure switch is stuck. This would be no water situation If high pressure from city water hit the pump the switch might be bad.
Sent from my Z30 using Forest River Forums mobile app
B and B
10-17-2014, 08:17 AM
Pumps do go bad. Mine did after a couple years. Replacing the pump is easy. Check out my previous post about my pump dilemma.
http://www.forestriverforums.com/for...ces-55252.html
Hank
10-17-2014, 02:00 PM
Had the same problem last month, pump was bad, had to replace it.
10-17-2014, 05:20 PM
Hit the pump and it started working. Turned off water. Turned water back on pump quit working again. Tapped on pump started up again. Turned off water, pump stopes. Turned on water again pump not working. What do you think? I am thinking new pump, what model?
