Old 01-20-2016, 05:17 PM   #21
RKNOLA's Avatar
Originally Posted by gasman94 View Post
I am thinking along the same lines. But for all of the doors, giving the possibility of central locking for the whole coach....just like the big boys! You could also wire locks to have a separate switch for the pump compartment door.
Rich
although you wouldn't be able to lock the propane door. Legally it has to be open at all times in case of fire. Installing a lock on it is a ticketable offense.
Karen
Rick and Karen
2018 Berkshire XL 40C
2011 Honda CR-V toad FB
RKNOLA is offline   Reply With Quote
Old 01-20-2016, 06:20 PM   #22
silver's Avatar
Originally Posted by accumack View Post
I've thought about adding these I'm not sure they are long enough to fit our doors.
http://www.amazon.com/gp/product/B00...=sr_1_2&sr=8-2
I looked at these. Been looking for cam locks for three years. No one makes one long enough for our thick Berk doors.
I would love to find a combination cam lock. I have also thought about modifying a cam lock to make it longer.
silver is offline   Reply With Quote
Old 01-20-2016, 06:27 PM   #23
Silver I'm not sure of this answer without going out and measuring the thickness of the bay doors. Do you know how thick they are ? Wanting to know for length of cam lock that would be needed.
Joe & Lori
2014 Berkshire 390 RB-40
5456Mich is offline   Reply With Quote
Old 01-20-2016, 06:39 PM   #24
silver's Avatar
I have forgotten. I measured once. Could never find a cam. Called several manufactures and was told they are not made that long. I want to say we would need 1 1/2 to 1 3/4 length.
Doors are much thicker than fuse panel door.
Old 01-21-2016, 09:15 AM   #25
accumack's Avatar
I've found quite few that are 1 3/4". Here's one.
Cam Lock, 1-3/4 - ESP
I even found a 2" one.
http://www.rvpartscountry.com/2-inch-RV-Cam-Lock.html
2011 Berkshire 390-rb-40, upgraded tires and front axle airbags, 2012 Jeep Wrangler 2 door, Blue Ox baseplate and BlueOx aladdin tow bar, Blue Ox Patriot brake system, wiring run through right frame rail and homemade led taillight bar.FB.
Ham KG5LTL.
accumack is offline   Reply With Quote
pump, water, water pump
