Old 02-08-2019, 03:51 PM   #1
Motorhome newbie
Water tank access
Really new to this rig and don't want to something stupid.
Looks to me like access to the water tank is on the passenger side; I think I can see it behind a white 1/4" panel shown in the picture.
I want to do an anti-siphon mod but need to remove the white panel for access. It appears that 2 screws near each vertical gasket might be holding it. Is removing the screws the proper method for removing the panel - or how?
What's the purpose of that panel anyway?
Thanks.
John, KA6CHX
2018 FR Berkshire 39A
DogFather is offline   Reply With Quote
Old 02-08-2019, 04:04 PM   #2
Dragonship Captain
Oscarvan's Avatar
That is known as the "useless white panel".
Yes, a few screws and it's out. Mine sits somewhere in my workshop as I have done a few mods there.
Each coach is a little different so although likely you may or may not find the vents behind it. The tank runs almost the full width of the coach so things are on either side.
Keep digging. You'll get to it. If you want take the panel off and post another picture... folks can look at it here.
Read about our 2017 38A: https://dragonship.blog/
Oscarvan is offline   Reply With Quote
Old 02-11-2019, 08:09 PM   #3
Motorhome newbie
Thanks, Oscarvan!
I removed the panel today which exposed the mystery (to me) behind.
I assume lines "C" are vents/overflows. Looks like they loop up then both head down by the right water tank corner to discharge below (where they are barely seen in the picture).
Line "B" is the water fill?
Are tanks "E" and "F" the gray and black?
What is line "A", black vent?
Confirmations/corrections/comments appreciated.
Thanks.
Name:	Water tank lines.JPG
John, KA6CHX
Old 02-11-2019, 08:49 PM   #4
Dragonship Captain
Oscarvan's Avatar
Yup, that sounds about right with I believe F being the black tank and A being where the tank flush sprayer nozzle is. (The one you connect the hose to on the other side when you're dumping and rinsing.)
You can confirm that the black handle is on your left and the gray handle on your right on the other side....
Old 02-11-2019, 08:52 PM   #5
Motorhome newbie
Thanks!
John, KA6CHX
Old 02-11-2019, 08:55 PM   #6
Dragonship Captain
Oscarvan's Avatar
Looks like the black piece is also only attached with two screws. You can explore further.....
Old 02-12-2019, 12:47 AM   #7
planopat's Avatar
Correct on the handles. Also the "F" tank is narrower and less capacity so it will be or should be the black tank.
Also, while you're there, you might want to secure the black steel plate with more screws and/or a couple of rubber pads between the back of the plate and the frame that it attaches to. Just yesterday I put a couple of pads in as the steel against steel vibration can be very annoying. It took me a while to locate it as the source of the rattle that I've experienced.
planopat is offline   Reply With Quote
Old 02-12-2019, 11:57 AM   #8
Motorhome newbie
Thanks for the info & tips, guys!
Yes, the dump lines on the other side match the tank locations on the passenger side.
John, KA6CHX
Old 02-14-2019, 01:23 PM   #9
40C
On my 40C, the line you have identified as B is not connected. My water fill is on the other side, closer to the connection.
I will eventually use that connection to water tank for the water bypass system called showermeiser.
If you have a showermesier installed, it might be the return from the shower, as it doesn't sound like FR to run a line of PEX across the coach, when they can access the FW tank right next to the connection point in wet bay on other side.
2018 FR Berkshire XL 40 C
2016 Jeep Cherokee Trailhawk
BlueOx Avail TowBar
raidernation is offline   Reply With Quote
Old 02-14-2019, 05:35 PM   #10
Dragonship Captain
Oscarvan's Avatar
Good point, it may be the showermeiser.
That said, on mine there is no showermeiser and the fill IS on the passenger side...
tank, water, water tank
