Old 09-28-2016, 02:05 PM   #111
15berkxl's Avatar
My DW yells at me every time I slam the door. I told that the only way you can lock the deadbolt.
Wayne
Wayne
15berkxl is offline   Reply With Quote
Old 09-28-2016, 05:42 PM   #112
I-RV's Avatar
Wayne
The door latch has some sort of mechanism that holds the door more firmly closed when slammed. When traveling, if we do not slam the door, there is a lot of air noise. Slamming the door makes it quite.
Hank
Gale & Hank- 2012 Berkshire 390BH
I-RV is online now   Reply With Quote
Old 09-30-2016, 11:59 AM   #113
Originally Posted by Dbt803 View Post
Would love to see pictures. I too have been thinking about removing the loveseat.
Sorry down loaded all photos in my phone I will try to use my computer. We are in the process of getting new phones.
outloud is offline   Reply With Quote
Old 10-06-2016, 06:13 PM   #114
I-RV's Avatar
My headlight lens were getting very gray. I decided to see if I could restore the lens back to being very clear. I used the Turtle Wax Lens Restore Kit. Upon doing step #1 with the lens clarifier, I was amazed. The pictures show the difference. I did not do step #2 at first, which is meant for non-transparent lens.
I did run into problems with step#3, which apply a base coat and then a sealing coat. It left a film on the lens and I had to go back to stem #2 to try to remove the film. If you do step #3, I would suggest applying to one corner of the lens to see how it works out.
Hank
Name:	Lens Before.JPG
ID:	122280   Click image for larger version
Name:	Lens After.JPG
ID:	122281   Click image for larger version
Old 10-06-2016, 07:46 PM   #115
ernest917's Avatar
Easiest way to clear foggy lens - spray with deep woods mosquito spray and wipe with soft cloth ....
You will be amazed !!!!
ernest917 is offline   Reply With Quote
Old 10-24-2016, 07:26 AM   #116
BamaBob's Avatar
Wayne & Hank,
Started doing this IOT lock the deadbolt. The guy in the Airstream next door wandered by yesterday and asked why I was slamming the door at 10PM. I told him and guess what? Turns out Airstream has similar construction!
He went to his rig, slammed the door and came back 5 min later and said that was the first time in almost 2 years of ownership he was able to lock his deadbolt!
Nights Camped: 2013 - 24 2014 - 42 2015 - 56 Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 10-24-2016, 07:30 AM   #117
BamaBob's Avatar
Here is the tank bay. the foam insulation was a tad easier here: I was able to fit the foam behind the flange around the bay door. Same construction: R85 pink with 2 layers of heavy duty restaurant-grade aluminum foil secured with metal duct tape.
Nice thing about this is it is easily removable to service the water pump if necessary. Since all the tanks have heaters, I believe that this and the insulation on the opposite wet bay door will seal this part of the bus off and retain heat in the compartment while radiating heat up from the pads and down from the floors.
(I will let you know how THAT is working in January
Not shown: remote temperature sensor next to water pump.
Name:	Tank Bay-1.jpg
ID:	123734   Click image for larger version
Name:	Tank Bay-2.jpg
ID:	123735   Click image for larger version
Name:	Tank Bay-3.jpg
Old 10-24-2016, 08:44 AM   #118
BamaBob's Avatar
Sooooo getting ready for winter (since we cannot make the run to the sun for another year yet )
I figured the 2 points of failure in cold weather are the wet bay and the tank bay. Found some R85 Pink insulations that I cut to size for both bays.
First two photos are the wet bay. Photo to left is bare door, photo to right is insulating foam cut to fit, lined with restaurant-grade heavy duty aluminum foil (2 layers) and secured with metal duct tape.
Mounted to door with 15# double sided mounting tape. Nice snug fit. If necessary, will add a small incandescent light, but I think the radiated heat from the tank heaters and the heated floors will work.
Not shown: remote temperature monitor & #1 steel wool barriers at water hose inlet & sewer outlet.
Name:	Wet Bay-1.jpg
ID:	123742   Click image for larger version
Name:	Wet Bay-2.jpg
Old 10-26-2016, 06:31 AM   #119
Great Idea, I will give that a try myself. Trying to not winterize as we are going to Fla after the New Year.
Are you going to put non-toxic antifreeze in your fresh water tank and thru the pump piping?
Joe & Kathy
2017 Dynamax DX3 37BH
Toad: 2016 Ford Edge
2016: days camped 60
2017: days camped 26
joet19711 is offline   Reply With Quote
Old 10-26-2016, 12:20 PM   #120
BamaBob's Avatar
Joe,
I don't think so - I am hoping the tank heaters and daily use will prevent any bad things from happening
Also, the park we are at has a sign posted in the laundry room that if the temperature drops below 32 to leave both hot and cold taps on at a trickle and the gray tank open. If I have to do that, hope for not too long - I can only imagine how much propane that would eat!
berkshire
