Old 01-24-2015, 04:39 PM   #1
What type of coolant to add?
Starting my rig after sitting for 2 months. I get a "low coolant" orange dash check engine light.
Looking at the coolant reservoir (behind the power steering reservoir!) it's showing just barely below the Min line. I don't believe there is any leak...I noticed it slightly low last fall.
Question is:
1. Can I buy antifreeze for this at Walmart or Napa, or do I need to get something "fancy" from a dealer? I saw something about pink or clear antifreeze being the right stuff (extended life?) and not the green stuff. Can anyone offer any advice?
2. The power steering fluid tank has a sticker that lists the coolant fill procedure that is quite involved. I'm thinking that those instructions must apply when draining and refilling, but probably don't apply when I'm just topping off the reservoir tank. Is that correct?
Thanks!
chesterhull is offline   Reply With Quote
Old 01-24-2015, 04:45 PM   #2
Question is:
Thanks!
Most antifreeze you find at Walmart will be Green and list that it is compatible with all other types. If you have the year and make of you chassis would be helpful.
TheOrrs is offline   Reply With Quote
Old 01-24-2015, 04:45 PM   #3
Ford Idaho's Avatar
You need to buy what the engine suggests so what you need depends on the engine you have.
There may be a label in the engine compartment that will have the suggested type listed.
What color is in the tank?
Old 01-24-2015, 04:52 PM   #4
I'm sorry...I neglected to post the details of my chassis!
It's a 2008 Berkshire, running on the Freightliner chassis with the Cummins ISB engine.
Thanks!
Old 01-24-2015, 05:03 PM   #5
Thanks!
OK you want to spend the extra money on good coolant for the diesel.
All I found on a quick search is low-silicate antifreeze.
Peak, Valvoline, and Motorcraft all make Diesel antifreeze.
Old 01-24-2015, 05:55 PM   #6
Ford Idaho's Avatar
You should be able to buy the correct type at any auto parts store you have locally, Pep Boys, O'Reilly's or NAPA.
Old 01-24-2015, 06:08 PM   #7
2007 WildCat 32QBBS
05CrewDually's Avatar
Pull a sample and note the color first. It will probably be red, which is an ELC1 type coolant, so only use that. Never just grab a "compatible" coolant. Match the color at the very least.
05CrewDually is online now   Reply With Quote
Old 01-24-2015, 06:37 PM   #8
NV245's Avatar
Name:	ImageUploadedByForest River Forums1422142440.707162.jpg
ID:	68795 NAPA carries it at their larger stores. Note it is for Cummins heavy duty. While you are at it check your radiator pressure cap and also look at the heater shutoff valve in the generator compartment.. If needed, the shutoff is the same as a 1978 Chevrolet pickup, V-8 equipped, with A/C.
NV245 is offline   Reply With Quote
Old 01-24-2015, 07:22 PM   #9
2007 WildCat 32QBBS
^^^^^ That's the stuff!
Old 01-24-2015, 08:15 PM   #10
silver's Avatar
you want to use FleetCharge.
silver is offline   Reply With Quote
