05-31-2015, 05:49 PM
Where is (is there) an air jack on my Berk?
Hi folks,
I have a 2008 Berkshire 390QS and I've seen folks talking about an air jack (port) on their rig which is really an air inlet for a tow truck. But I've read that it can be used as an air supply to pump up tires, etc.
I was under the impression that if you had air brakes/air susp., such a port would exist. I've looked all over my front end (around the gennie) and I can't find one...
Did FR not include one back in 2008? If I'm looking in the wrong spot, I'd sure appreciate a pointer!
Thanks,
Mark...
05-31-2015, 07:05 PM
Firewall behind generator on most.
Not sure about 2008.
Dan
2014 Berkshire 390RB-60
05-31-2015, 08:22 PM
Berkshire 390QS
Firewall above generator on 2009 390QS?
2015: 188 days, 2016: 72 days, 2017: 185 days: 2018 182 days
2019: 156 days (2009 Berkshire, 390QS, and toad)
06-01-2015, 05:22 AM
On my 2014 390 FL. Up near top of firewall above generator on passenger side
Russell
06-01-2015, 06:44 AM
I had an '08 and it was in the same spot.
Tom and Margaret
2014 Berkshire 390bh-60
06-01-2015, 07:52 AM
On my "08" the location and plug was there but I had to have the actual fitting installed.
GOOD LUCK
AREA51
06-01-2015, 09:45 AM
Can u install the fitting yourself??? I'd like to install one in mine... An precautions I should know about??
06-01-2015, 10:08 AM
No problem. Go to Napa get a quick connection fitting. Take out the plug put new fitting. Easy
Russell
06-01-2015, 11:58 AM
Should I deflate my air bags to remove some pressure??? If I pull that plug as is, won't it be under 125 psi ?
06-01-2015, 03:07 PM
Ok, so the $64,000 question, is it a 1/4" or 3/8" fitting?
06-01-2015, 03:23 PM
If the compressor can keep up get the 3/8 but the 1/4 will do.
06-01-2015, 04:14 PM
Pump your brakes to bleed off all the air. All of it!!!
Russell
06-01-2015, 08:22 PM
Pull all three lanyards located in the front wheel wells. That will drain all the air in the tanks.
06-04-2015, 08:35 AM
1/4"
06-06-2015, 10:22 AM
It seems like some of the 08s didn't come with the valve. Mine didn't I installed my own. Jim
06-06-2015, 11:10 AM
My 10 berk has one. it doesn't have a vale on it. But comes straight in top right on the brace.
06-06-2015, 12:00 PM
I moved the air horns downward and hung 50 ft of air hose next to the air coupling. I'm sure there are other ides, but maybe you would be interested in this one - LOL
Gale & Hank- 2012 Berkshire 390BH
