Old 06-04-2015, 02:33 PM   #1
Whirlpool fridge
Does anybody know where the drain line in the fridge is located. My unit drips from the front left corner.
Paulie Boy is offline   Reply With Quote
Old 06-04-2015, 06:21 PM   #2
It's probably from the inlet tube for the ice maker which is on the left side. Mine leaked there.
uralman is offline   Reply With Quote
Old 06-04-2015, 10:56 PM   #3
dan-nickie's Avatar
Drain line? My home fridge doesn't have a drain line. I would not expect my whirlpool in the Berk to have one either.
I think you have a leak maybe.
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 06-05-2015, 05:47 AM   #4
With the ice maker in the top refer section there should be a drain line to the evap tray in the bottom of the unit.
Old 06-05-2015, 07:32 AM   #5
dan-nickie's Avatar
Gosh, I didn't even know refrigerators still had an evaporation tray. Shows you how much I know about refrigerators. :-)
Dan
Old 06-05-2015, 01:49 PM   #6
The connection for the icemaker is in the lower left corner even though the freezer in on the top. Either way you need to pull the frig to fix it.
Old 06-05-2015, 07:33 PM   #7
Whirlpool fridge
Well that sucks, but thanks!
Old 06-06-2015, 12:16 PM   #8
I-RV's Avatar
Frost-free refrigerators gather moisture during the defrost cycle and empty it into a pan (almost at floor level) beneath the condenser coils, The condenser coils get hot when the compressor runs and helps evaporate the water. Generally, there is a bottom front panel that comes off to allow cleaning of the condenser fins with a brush.
I never noticed how much water is produced in my home refrig., but it leads to the question when in an RV that moves, tilts and sways, does the water stay in the tray? Hmm!
Gale & Hank- 2012 Berkshire 390BH
I-RV is offline   Reply With Quote
fridge
