Old 09-04-2015, 12:32 PM   #11
No problem as long as fully charged at start of winter. I do it all the time.
Harkerr is offline   Reply With Quote
Old 09-04-2015, 12:44 PM   #12
Radio memory, CO detector and the HVAC thermostat are the things I would check for battery drain.
drc343 is offline   Reply With Quote
Old 09-04-2015, 01:14 PM   #13
Mmnsc's Avatar
When I turn off the switch located next to the house batteries it kills everything including the CO/LP detector, radio clock memory, refridgerator electronics, HVAC thermostat, etc. No need to dusconnect a cable as there is no parasitic drain from that point.
Mmnsc is offline   Reply With Quote
Old 09-04-2015, 02:46 PM   #14
This is my experience also. When my MH sat all winter it would be ok without a trickle charge. That said if electric is available I would put one on as a precaution.
battery
