Old 06-15-2014, 06:14 PM   #1
Why would my propane shut off?
In the middle of using my propane today, it shut off completely...no flow.
Yet I had just under half a tank. In fact, I thought maybe I was empty, but when I went to fill up, they could only put 7.3 gallons in!
My batteries were getting really low, so I'm guessing it's an electrical problem? Possibly a fuse on the LP ignitor?
Any ideas?
Thanks!
chesterhull is offline   Reply With Quote
Old 06-15-2014, 06:40 PM   #2
Berkshire 390QS
NO3putt's Avatar
Have you checked your CO dector? If it shut down due low voltage, your propane shuts off.
2015: 188 days, 2016: 72 days, 2017: 185 days: 2018 182 days
Old 06-15-2014, 09:44 PM   #3
Silly me...that was it exactly! The LP detector (down low on the floor) had to be turned off and back on. I'm guessing that it shut off due to low battery, or something fluke-y.
Thanks for the clue!
Old 06-15-2014, 09:50 PM   #4
NELA
Weezer's Avatar
And another problem bites the dust, at the fingers of this awesome group of people here!
If age is a state of mind, and I've lost my mind, I'm AGELESS, right?
Give me 40 acres and I'll turn this rig around:
Flagstaff 5er 2014 8528 IKWS, Platinum Package, Regency Interior "Buffy"
F250 Super Duty 2013 Tuxedo Black "Biff"
Days camped 2014: 30
Weezer is offline   Reply With Quote
Old 06-15-2014, 10:03 PM   #5
Absolutely! To say a simple "thanks" doesn't even seem to cut it!
Major thumbs-up to an awesome community!
Old 06-15-2014, 10:05 PM   #6
Berkshire 390QS
NO3putt's Avatar
We all have to stick together. Just think we all could be quality control technicans at the Berkshire plant! ooops I'm retired.
Old 06-23-2014, 12:28 AM   #7
Ericvr4's Avatar
also watch the gas solenoid valve , they go bad all the time .when co det alarms it releases the 12 volt to the valve causing it to close. you will see the valve is hot to touch because it is engaged all the time. i am on 2nd one i plan on installing a 12volt on/off switch at control panel so i can turn gas off manually. also saving life of gas solenoid valve
2011 Berkshire 390BH
Ericvr4 is offline   Reply With Quote
propane
