Old 03-06-2017, 04:53 PM   #21
dan-nickie's Avatar
Second link went to the wrong place for me. They're only six Post in the whole thread.
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 03-06-2017, 08:03 PM   #22
I-RV's Avatar
Dan
I re-copied the link; hope this works!
http://www.forestriverforums.com/for...bed-88290.html
Hank
Gale & Hank- 2012 Berkshire 390BH
I-RV is offline   Reply With Quote
Old 03-06-2017, 08:11 PM   #23
dan-nickie's Avatar
That one works.
Dan
Old 03-06-2017, 09:13 PM   #24
Pulled the mattress off the bed-
Ok so when I push the out button for the bed slide all I hear is a relay clicking under the bed. With a light I can see 2- 1 inch square relays on the back wall under the bed. But with the bed in I see no way to get to them other than cutting a 3 in hole in the plywood top. Any other ideas on how to get to the relays?
If I tap the in button- the motor tries to run- lights dim slightly- but with I push out I just hear the relay click.
dave-g is offline   Reply With Quote
Old 03-06-2017, 09:16 PM   #25
Dragonship Captain
Oscarvan's Avatar
Are you hearing a relay clicking or a gear?
2020 RAM 3500 DRW Long Horn. In the hunt for a Palomino TC, formerly a 2017 Berkshire 38A: https://dragonship.blog/
Oscarvan is offline   Reply With Quote
Old 03-06-2017, 09:26 PM   #26
I-RV's Avatar
dave-g
Check the easiest things first; like did you remove the swich panel and check out the switch? I had a problem with it.
Hank
Old 03-06-2017, 09:56 PM   #27
Yes. Switch is ok 12 volts out . Then I hear relay under bed click.
2012 390BH
Old 03-06-2017, 09:56 PM   #28
It's not the gear but a faint click
2012 390BH
Old 03-08-2017, 05:00 AM   #29
Well it was the relay. Had to cut the wood cover, so I could crawl under the bed/slide which was in. I then took the motor wires off and reversed them. Then when I pushed the in button the slide went out. What a pain in the *****.
Now I jut need to order relays.
2012 390BH
Old 03-08-2017, 08:06 AM   #30
Mmnsc's Avatar
Glad to hear you found the problem. You might be able to get the relay at an auto parts store since it is a 12 V system. Getting at the relays and motor are really a pain when the slide is in.
Mmnsc is offline   Reply With Quote
Old 03-08-2017, 09:38 AM   #31
World Wide Wanderer
wahoonc's Avatar
No way to put the slide out manually?
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2016 Coachmen Concord 300DS
2015 Fusion Hybrid following along
wahoonc is offline   Reply With Quote
Old 03-08-2017, 05:21 PM   #32
I-RV's Avatar
dave-g
Reversing the motor wires and pushing the In button which you know that works and using the In relay to make the bed go out, does not necessarily prove that the Out relay is bad and the Out button is good.
This did however at least get the bed out to gain access. I hope that a new relay works for you, but if not, I would say it is still at the switch.
Hank
Old 03-09-2017, 05:16 AM   #33
Originally Posted by I-RV View Post
dave-g
Hank
I was hopping it was the switch- but- I get 12 volts to the relay when I push the out button and when holding the relay in my hand I can feel and hear it click when energized.
I believe the contacts are burnt or fell apart. When I put the new ones in Ill cut the old one open to see.
Old 03-09-2017, 05:28 AM   #34
dan-nickie's Avatar
Apparently a minor issue with someone of your abilities. Enjoy the coach.
Dan
Old 03-09-2017, 04:44 PM   #35
Dragonship Captain
Oscarvan's Avatar
In the meantime you could jury rig wires to be able to operate it in the meantime. (a "human relay")
Old 03-09-2017, 07:20 PM   #36
accumack's Avatar
I think there was a problem with some motors for the bed slide.
2011 Berkshire 390-rb-40, upgraded tires and front axle airbags, 2012 Jeep Wrangler 2 door, Blue Ox baseplate and BlueOx aladdin tow bar, Blue Ox Patriot brake system, wiring run through right frame rail and homemade led taillight bar.FB.
Ham KG5LTL.
accumack is offline   Reply With Quote
Old 03-12-2017, 05:36 AM   #37
Well early in the week I contacted the factory for the relays under the bed. I know I could have gone to a few auto parts stores to try to match up but I could not read the numbers on the side.
I was very please with their fast response, and found out on the 2012 they used a 30 amp relay for the bed slide- but the newer models use a 40 amp. I ordered the 40 amp relays as they were only $2.00 more should last longer.
I also ordered a new drivers side wiper arm as the arm did not want to wipe the windshield past 12 o'clock. I got new blades as well.
While talking to the parts dept. I let them know that one of the reasons I bought my used Berkshire- is all the nice things that are said about the factory support on the forums. They were surprised and pleased.
camping, winter
