Couch is 2008 Berkshire 360 qs. Question: Where are the low point drains, hot and cold located? My last MH, not a Forest River, had clearly marked drains so I could drain all water out prior to adding antifreeze. Thanks for any and all suggestions.
On passenger side - open compartment where water pump is located (also find blk/grey tanks in there also); open all pitcocks in there and all water will drain.... I also turn on water pump and open ALL faucets after I've drained tanks and water lines... This removes all remaining water from lines...
