Old 11-13-2014, 08:05 AM   #1
Fulltime in our Berkshire
KennyGolub's Avatar
Winterize residential Fridge
I'm still not clear on how I can "blow" the water from the lines that feed the icemaker in my residential fridge. How do you get the line to open ?
Ken
KennyGolub is offline   Reply With Quote
Old 11-13-2014, 09:45 AM   #2
tmmar's Avatar
Ken,
I hook up my compressor to the fresh water inlet in the water bay and turn it on. I then go around opening all the taps (hot, cold, toilet, cold water on the fridge door) until only air comes out. It seem that by the time all that is done, hopefully the ice maker will have cycled once, as if it were making ice, and the valve opened and blown the got water out. I did the same thing when I pumped the pink antifreeze through. It didn't initially come out of the icemaker but the next day when I checked, there was pink fluid in the ice bin in the freezer.
Tom
Tom and Margaret
2014 Berkshire 390bh-60
Old 11-13-2014, 09:48 AM   #3
KennyGolub's Avatar
Originally Posted by tmmar View Post
Ken,
Tom
Thanks for the reply Tom.
I already pushed air thru the sink, shower, etc. But wasn't sure how to get the lines in the fridge to open. The water line for a glass of water on the door was easy enough. So I guess you're saying open everything up, turn the fridge and ice maker on, the sit back for a while and wait for it to turn on?
Thanks Again
Old 11-13-2014, 09:56 AM   #4
tmmar's Avatar
Ken,
yes- that's what I did. While your doing that you can also run the washer/drier through a cycle to blow the water out of the lines running to the machine.
Tom
Tom and Margaret
Old 11-15-2014, 08:01 PM   #5
ndfellow's Avatar
I had mine winterized in Adahl and they disconnected on fridge side and drained it then they put anti freeze to the connector. I have a picture if your interested so I remember how to hook up!
ndfellow is offline   Reply With Quote
Old 11-16-2014, 08:14 AM   #6
KennyGolub's Avatar
PLEASE do send a pic. I spent a half out with air going in and the ice maker on and still not sure if I got water out of the lines. I did get all the water out of the cup filler, but don't have a clue about the ice maker.
Thanks !
Old 11-16-2014, 09:01 AM   #7
ndfellow's Avatar
Name:	ImageUploadedByForest River Forums1416150012.411472.jpg
ID:	66470. They unplugged. The red wire on right disconnected One side and got antifreeze to the other. Not sure it helps but good luck
Old 11-16-2014, 09:40 AM   #8
tmmar's Avatar
nd,
Looks like you have the Dometic refrigerator in your coach with an outside access panel. With the residential refrigerator, there is no access panel of any type to get to the back of the refrigerator.
Tom
Tom and Margaret
Old 11-16-2014, 11:55 AM   #9
ndfellow's Avatar
nd,
Tom
Yes sorry!
fridge, winter, winterize
