Old 10-10-2015, 03:09 PM   #21
Good job. It's sad to think about putting them away with weather like this. Snow is coming soon.
Old 10-10-2015, 03:26 PM   #22
15berkxl's Avatar
Phil bet you had a huge grin on your face when you said that.
Wayne
Wayne
15berkxl is offline   Reply With Quote
Old 10-10-2015, 04:15 PM   #23
A little.
Old 10-10-2015, 04:20 PM   #24
silver's Avatar
Originally Posted by gasman94 View Post
Just (almost) finished winterizing the Berk. I opened the overflow/pressure relief valve on the demand water heater and let the pink stuff flow out. Can't believe I paid big bucks to do this job before. I've got the ice maker on right now and the system pressurized until I see some pink at the ice maker. Also used 6 gallons and put some no stinkum in the black and grey tanks. Also did generator service...oil, filter and coolant. No air or fuel filters...only 27 hours on genny.
Rich
Don't forget the oil and filter on the Berkshire engine. Should be done every year no mater the mileage. Not good to let old oil sit in engine for the winter as it turns acidic during use. I did the Berk engine and Generator myself today. Currently draining the fresh water tank. Through that 1/2 inch line should not take more that two days
silver is offline   Reply With Quote
Old 10-10-2015, 05:16 PM   #25
gasman94's Avatar
Silver, got that done at the oasis dealer. Oil/filter/fuel filter/water separator/lube and 37 point inspection....$214 out the door. Couldn't pass it up for that price.
Phil, I can see that grin from here Sad time of year to put away my baby! Couple more years and I'll be able to go south.
Rich
gasman94 is offline   Reply With Quote
Old 10-10-2015, 06:21 PM   #26
I know you will Rich. Probably in a big tag Berkshire. LOL
Old 10-10-2015, 07:03 PM   #27
gasman94's Avatar
Ya, that sounds like a plan
Rich
Old 10-10-2015, 09:07 PM   #28
Herk7769's Avatar
Awesome discussion. Filing away tips for December.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 10-10-2015, 11:12 PM   #29
Ĺiving in Alberta, proper winterization is extremely important.
Having burst lines in the past, I tend to err on the safe side.
I start the process by blowing all of the lines with my compressor. I have made a small brass fitting that consists of an airline quick connect, a ball valve and a male hose connect.
I connect my adapter to the city water inlet and to my compressor. With all taps closed I pressure up the system. One by one I open one outlet at a time.
I start with each of the two low point drains in the wet bay. Next the outside shower, kitchen sink, bathroom sink, toilet, toilet hand spray, shower, washing machine, drain behind water heater. Repeat all twice.
I then run antifreeze thru all lines as above. Making sure to fill each trap with antifreeze.
Once this is complete I blow all lines clear. This final.stage ensure that you do not have excess antifreeze taste in the spring.
Prior to doing any of this it is important to remove filter from canister.
This may seem like overkill but the entire process only takes about 30 minutes
lefaivre is offline   Reply With Quote
Old 10-11-2015, 04:50 AM   #30
Lefaivre,
I liked your explanation as I still need to winterize mine. Although when I got to the statement above I'm a little confused and need to clarify.
Do you do this step directly after putting the antifreeze in ?
Or is this step done in the spring when dewinterizing ?
Joe & Lori
2014 Berkshire 390 RB-40
5456Mich is offline   Reply With Quote
Old 10-16-2015, 10:03 PM   #31
I purge with air, fill with antifreeze and drain antifreeze all before storing for the winter.
I have found in the past that leaving antifreeze in the lines all winter leaves a residue that can sometimes last much of the summer.
Once the antifreeze has filled the lines ... it has done it's job. No need to leave it in the pipes.
Old 10-17-2015, 04:35 AM   #32
Interesting idea.
Haven't winterized mine yet and will be the first time doing so. I would be interested in hearing other opinions on this matter.
Joe & Lori
Old 10-17-2015, 07:36 AM   #33
15berkxl's Avatar
If you are blowing out lines etc you are getting all the water out you don't need AF. Only put it in the traps and toilets.
Wayne
Wayne
Old 10-17-2015, 07:43 AM   #34
I-RV's Avatar
Wayne
X2 to that, I have been doing that for years. I however do inject a little antifreeze into the water pump and its line which merges with the city water, which doesn't get blown out.
Gale & Hank- 2012 Berkshire 390BH
I-RV is offline   Reply With Quote
Old 10-17-2015, 08:52 AM   #35
You guys are going to drive me to drink !
Joe & Lori
Old 10-17-2015, 09:29 AM   #36
It's a short drive for most of us Joe. Don't fight it.
Old 10-17-2015, 10:07 AM   #37
accumack's Avatar
I just drive to warmer weather to winterize. LOL
2011 Berkshire 390-rb-40, upgraded tires and front axle airbags, 2012 Jeep Wrangler 2 door, Blue Ox baseplate and BlueOx aladdin tow bar, Blue Ox Patriot brake system, wiring run through right frame rail and homemade led taillight bar.FB.
Ham KG5LTL.
accumack is offline   Reply With Quote
Old 10-17-2015, 10:29 AM   #38
My psychiatrist thought I was doing so well the last time I visited.
( joking guys, don't want you to think you got some nut job at this end ) lol
Joe & Lori
Old 10-17-2015, 11:54 AM   #39
Can someone tell me if there's a main drain to get the water out of the fresh water tank ? Or does it have to get pumped out from water pump ? Can you tilt the coach to one side by using just two jacks on either side ?
Joe & Lori
Old 10-17-2015, 01:06 PM   #40
15berkxl's Avatar
1/2 inch drill bit NO WAIT DONT DO IT. I think mine has a tank drain but it's in that damn compartment I refuse to open.
Wayne
Wayne
berkshire, motorhome, winter, winterize
