Old 07-29-2019, 11:53 AM   #1
Wiring Diagram
Anyone happen to have a complete wiring diagram of the house electrical system for a 2011 390RB Berk?? Or other year if equivalent??
Water pump and tank indicator lights have quit working. Checked fuse; no help.
Thank you
kaymfischer is offline   Reply With Quote
Old 07-29-2019, 02:16 PM   #2
Berkshire 390QS
NO3putt's Avatar
Don't think anyone will have the drawings. Have you checked the connections on the switches? Skip
2015: 188 days, 2016: 72 days, 2017: 185 days: 2018 182 days
Old 07-29-2019, 05:55 PM   #3
They may share a ground, which I bet isn’t too far away from the pump.
2016 Berkshire XL 40A towing 2016 Jeep Wrangler.
Prior to this Jayco fifth wheel: 24' Eagle, 30' Designer, and 40' Jayco pinnacle.
Igave is offline   Reply With Quote
Old 07-30-2019, 05:48 AM   #4
I had a copy of this not your year but it may give you some idea of layout of wiring.
File Type: pdf RV Wiring 0610-500173 REV F (2018_02_05 03_48_33 UTC).pdf (326.0 KB, 44 views)
2012 390BH
dave-g is offline   Reply With Quote
Old 07-30-2019, 07:04 AM   #5
Thanks to all for the replies. dave-g I will check your file
Old 07-30-2019, 03:39 PM   #6
RKNOLA's Avatar
That says "Unit Charleston 430RB" are those interchangeable with the Berkshire of 2014?
Rick and Karen
2018 Berkshire XL 40C
2011 Honda CR-V toad FB
RKNOLA is offline   Reply With Quote
Old 08-01-2019, 04:59 AM   #7
no not the same wiring but what I have found it at some things are similar, it puts you in their mind set of wiring.
But he should be able to call forest river and get it for his coach. they are available.
2012 390BH
diagram, wiring
