Old 04-29-2017, 05:40 PM   #1
XLT 43A 2016. Bedroom slide motor. Wires burnt can the slide be manually operated ?
New 2016 XLT43A. Bedroom slide motor wires burned. Dealer will replace but would like to know how to manually extend if possible.
Also any hints on how to easily replace. Very tight fit under bed even with front cover board off. Click image for larger version
ID:	136283Click image for larger version
SennsAway is offline   Reply With Quote
Old 04-29-2017, 06:32 PM   #2
The only way I know of is loosen the motor bolts and drop it down enough to disengage the teeth and then PUSH!!!
If you need to drive the RV you will need to use a piece of 2 by 4 and jam the slide closed so it can't come out while driving.
Bill
2015 Charleston 430RB
Billr is offline   Reply With Quote
Old 05-01-2017, 11:35 AM   #3
BamaBob's Avatar
YIKES! Any idea why the motor wires burned?
Nights Camped: 2013 - 242014 - 422015 - 56Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 05-01-2017, 06:54 PM   #4
Don't know why wires burned. Poor installation or factory defect I suppose. Waiting on new motor. Any idea on how to manually move the slide out? Currently it is in and would like more room while waiting on motor replacement
Old 05-01-2017, 09:16 PM   #5
BamaBob's Avatar
See Bill's Post - #2 in the thread on how to manually open the slide
Old 05-01-2017, 09:47 PM   #6
Dragonship Captain
Oscarvan's Avatar
Replacing the motor may or may not fix the problem. Did the circuit protection work? Not enough to stop this from happening, it is not supposed to. I would want some serious answers to serious questions from whomever makes the repairs. "Supposing" is not enough.
A lot of burnt Moho's came from burnt wires.
2020 RAM 3500 DRW Long Horn. In the hunt for a Palomino TC, formerly a 2017 Berkshire 38A: https://dragonship.blog/
Oscarvan is offline   Reply With Quote
Old 05-15-2017, 09:38 PM   #7
mikeborny's Avatar
I can not believe they have not changed the power design on this slide. I have a 2014 390bh and have been pushing my bedroom slide in and out for almost 9 months now. New motor was expensive and I would have the same problem with it not engaging. I stripped the screws tightening this one and it was damaged by me trying to wedge it up so it would engage.
mikeborny is offline   Reply With Quote
Old 05-16-2017, 08:32 AM   #8
AREA51's Avatar
Bed Slide Motor
My 2008 has the same motor, in my case the mounting ears on the motor housing failed. The part is exclusive to the slide manufacturer and cannot be bought from the motor manufacturer. This design (at least in my coach) has no limit switch so the slide can be fully extended or retracted and the motor can still be running. Could your motor have overheated because the power stayed on too long?
Like mikeborny I pushed and shoved the thing all last winter, finally bit the bullet and had the unit repaired. Saved the old motor and housing. Notice the housing and how the mounting ears failed.
GOOD LUCK
AREA51
ID:	138071   Click image for larger version
AREA51 is offline   Reply With Quote
Old 05-17-2017, 08:37 AM   #9
AREA51's Avatar
In response to Billr, my Berk came with a set of slide-locks one for each slide. Hopefully we all have them as thy do come in handy.
GOOD LUCK
AREA51
Old 05-17-2017, 06:09 PM   #10
Our 40A did not. We probably should ask FR whether there should have had them.
2016 Berkshire XL 40A towing 2020 Jeep Wrangler unlimited.
Prior to this Jayco fifth wheel: 24' Eagle, 30'Designer, and 40' Jayco pinnacle.
Igave is offline   Reply With Quote
bed, bedroom slide, manual, roo, slide
