Old 12-31-2018, 02:44 PM   #11
Newly Retired
Steveboe's Avatar
Buy the Good Sam towing service for a year and hit the road. At least you have coverage in case you have trouble.
Steveboe is offline   Reply With Quote
Old 12-31-2018, 02:46 PM   #12
CAT-RN's Avatar
yellow engine light on dash-how far can I go before the engine shuts down
Originally Posted by Kuppajoe View Post
After 48 hours of constant rain, our DP check engine light came on in Dothan, AL. I kept driving and the regent light came on. I kept driving and the regen light started flashing. I kept driving because like you, it was Saturday. I fueled up south of Ocala, FL just 10 miles from my campground. The stop engine light came on in red, the engine derated and would only craw along about 5 mph. I had to be towed by a huge wrecker back to Ocala. I am now at Cummins coach care, have over a dozen fault codes and the problem is a bad sensor in the coolant system. So like Clint Eastwood said, "Do you feel lucky?"
Similar here: I left home went about 6 mile. The stop engine light came on. About a mile later the motor shut down. It started back up and I turned around to get back home. Coach would run up to 60 MPH and die again. Was able to do that three times and get back home.
My mechanic hooked his computer to the motor. Talked about a nox -issue best I remember. He did a forced regent on it. Could find nothing else wrong with it. 15,000 mile later never another issue.
Russell
CAT-RN is offline   Reply With Quote
Old 12-31-2018, 03:17 PM   #13
dan-nickie's Avatar
My mechanic hooked his computer to the motor. Talked about a nox -issue best I remember. He did a forced regen on it. Could find nothing else wrong with it. 15,000 mile later never another issue.
Russell
On the truckers Websites I was reading A bunch of them said that a parked regent might clear the issue.
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 12-31-2018, 03:20 PM   #14
CAT-RN's Avatar
Yes a forced regent not hurt a thing. Even if no lights are showing.
Russell
Old 12-31-2018, 03:38 PM   #15
oldprof1's Avatar
Usually the check engine light is a warning that there is a potential problem. However if the light flashes then it is serious. So a steady light means have it attended to in the near future no immediate need to service today
Snow bird in naples
oldprof1 is offline   Reply With Quote
Old 12-31-2018, 06:00 PM   #16
tmmar's Avatar
Well, to start with, I did not fell lucky at all. I started the trip off with a huge rock hitting my windshield and putting a silver dollar sized (maybe larger) multi point star in the windshield. Not a pretty sight and probably not repairable- meaning that the windshield will need to be replaced. Then when the yellow icon came on I didn't want to take any chances. I got to a Freightliner dealer/service center at 6 am this morning because I wanted to make sure they were going to be able get me in and check out my coach. The service tech came out with his laptop and hooked it up. He then proceeded to tell me that there were 18 entries for the same issue - none of them were active. I asked if the nox sensor needed to be replaced and said no. He did say that there were updates to the software and he could do the update -for a nominal fee- $175+tax. He said that the updated software takes care of a lot of issues that normally cause a warning light to come on. So, I had the update done (my coach had version 20 of the software and the new versions were in the 40'a) so there were many revisions to the software that were not installed in my coach. So, that's where we stand so hopefully this will take care of any other issues as well.
Tom and Margaret
2014 Berkshire 390bh-60
Old 12-31-2018, 07:32 PM   #17
CAT-RN's Avatar
Well that sounds like a good deal. To get thru a Freightliner door for less than $200 is amazing in itself!! Best of luck. Hope they got it fixed.
Russell
Old 01-01-2019, 07:41 PM   #18
CZNEDY's Avatar
Glad to hear it worked out for you Tom. Safe travels.
2018 BERKSHIRE 34QS
2004 Jeep Wrangler and a
Cooler full of good ideas
Days Camped, Not Enough
CZNEDY is offline   Reply With Quote
Old 01-01-2019, 08:07 PM   #19
Dragonship Captain
Oscarvan's Avatar
Glad you're back on the road.
This is an FIY as it came up above. And, as always, this applies to many but not necessarily ALL BERKSHIRE chassis (although I don't know of any where it does NOT apply) Yes, this is a BERKSHIRE forum.
YOU CAN NOT DO A FORCED REGEN ON THESE UNITS.
When it starts bitching at you you can only hope that all it needs is a regen and get on the highway and get motoring at speed for a half hour. If there's something else going on that won't help....
As always, read the book for the specifics here.
Read about our 2017 38A: https://dragonship.blog/
Oscarvan is offline   Reply With Quote
Old 01-02-2019, 05:17 AM   #20
CAT-RN's Avatar
I know nothing about your 2017 unit. But on my 2014 FL 390 there is a shorting plug on the steering column that will allow for a forced regen. Hard to get to first time as it is in a cluster of wires. But unplug that switch and plug it back in and the regen will start. Mine may be the only one in the country with this set up but I doubt it !!
Russell
light
