Old 04-30-2016, 11:53 AM   #1
mgargiullo's Avatar
1056 LED Replacements?
My Rockwood has a few fixtures that use a double pin 1056 bulb. Has anyone seen a good warm LED bulb for these?
I have a bunch of 1156 (single pin) led bulbs which were sold as 1056 bulbs from Amazon already. It appears that most LED bulbs I find when searching for 1056 bulbs are actually 1156 single pins.
Ideas?
2017 GMC 3500 Denali HD
2010 Rockwood Signature 8316SS
mgargiullo is offline   Reply With Quote
Old 05-02-2016, 11:05 AM   #2
Head Rambler
What you have is most likely a 1076 or 1142 lamp. 1056 is a single contact lamp. 1076/1142 is dual contact with parallel pins.
I think if you'll search for those numbers you'll find what you need.
Gotta go campin!
Old 06-15-2016, 10:21 PM   #3
The 1056 bulb is the standard type bulb used in all the old style fixtures. Camping World has them but for an arm and a leg. Try the auto stores. They're cheaper. If you can wait, I got 10 cool whites for around $6 and 10 warm whites for $8 off eBay. Do a little searching and you can typically find some of the Chinese sellers that maintain some warehouses in CA that will greatly reduce the shipping time. Search eBay - 1056 LED warm.
safetychain is offline   Reply With Quote
Old 06-15-2016, 11:03 PM   #4
I go RV'ing not Camping
jgourlie's Avatar
I tried 2 times from eBay and they failed. One set even started on fire. Paid $16 a piece from the dealership and they work perfect. I should have went with the dealership straight off the bat even though we're pricey
312QBUD Owners Thread
2015 Wildwood Heritage Glen 312QBUD
2000 Chev 2500 Extended Cab 6 Liter
1400lbs Equal-i-zer Hitch
jgourlie is offline   Reply With Quote
Old 06-16-2016, 07:32 AM   #5
mgargiullo's Avatar
For $16 a bulb, I think I'm going to try and replace the fixture/bulb socket.
Thanks for the info!
led, replacement
