Old 05-13-2018, 01:58 PM   #21
He's only going to use the HDMI input
Originally Posted by Steve-W View Post
Bigger issue than voltage (easy to resolve), frequency (should not matter in this case), is the TV standard. US sets are designed to operate using the NTSC standard, NZ uses PAL. not 100% positive but this may be the showstopper for you.
Not an issue. The OP plans to use only the HDMI input, nothing over the air.
Larry
Larry-NC is offline   Reply With Quote
Old 05-14-2018, 02:33 AM   #22
Larry
I believe you are right Larry after more research, using HDMI will work fine also no problems using the Wifi, will be buying a Pure Sine Wave inverter rather then a Modified Sine Wave.
2015 Coachman Apex 22QBS 2015
savi18 is offline   Reply With Quote
110v
