Old 10-11-2014, 06:12 PM   #1
12 Volt Plug
I wired a 12 volt plug into the bedroom to run the tv but it comes on then shuts off. It will work in the trucks cig lighter socket. I just spiced into a light wire so Im thinking not enough power. Can you run to power legs into it to boost the power?
jm28257 is offline   Reply With Quote
Old 10-11-2014, 06:14 PM   #2
Probably need to run larger wires to the outlet.
jwedell is offline   Reply With Quote
Old 10-11-2014, 07:28 PM   #3
That sounds like a big pain getting them from the panel to the bedroom
Old 10-11-2014, 07:47 PM   #4
HONDAMAN174's Avatar
What style of TV is it? LED tv's run at an amazingly low wattage.
2014 Stealth Evo 2850 "Woodstock"
2011 Toyota Tundra Rock Crawler TRD 5.7 "Clifford"
Just glad to get away
HONDAMAN174 is offline   Reply With Quote
Old 10-11-2014, 07:49 PM   #5
Its an LED it does it when running the dvd
Old 10-11-2014, 07:53 PM   #6
raspivey's Avatar
Maybe I'm missing something here, but you did say you spliced into a 12V lighting circuit to run a TV? I'm going under the assumption that the tv is 110V here.
2015 Chevy Silverado LTZ - HD tow package
2017 Rockwood 2703WS Emerald Edition
raspivey is offline   Reply With Quote
Old 10-11-2014, 07:54 PM   #7
Ok...is the DVD part of the TV? Also, did you splice in and butt connect or use a t tap? Double check the connections as sometimes the wires are loose or slide halfway out before crimping.
Old 10-11-2014, 08:10 PM   #8
Yes the dvd is part of the tv and I spliced in and it's a 110v and 12v
Old 10-11-2014, 08:28 PM   #9
raspivey's Avatar
Originally Posted by jm28257 View Post
...and it's a 110v and 12v
Ah, just making sure. I knew such an animal existed, just haven't run across one in an RV yet. As suggested, it's very possible that the wire isn't heavy enough to allow sufficient current to flow while the DVD is running also.
Old 10-11-2014, 08:35 PM   #10
I'm afraid that the others may be right. Might be too far to send sufficient wattage. I have a 24" led @ 35 watts and the blue ray @ 25 watts. Difference is I wired in a 400 watt inverter and run them on 110v. 14 ga wire- max calculated amps is 7.
Old 10-11-2014, 08:47 PM   #11
I found a 12v extension cable and plugged it into the charging center and it works fine. The wire on this is pretty small not sure on the wire connecting the charging center plug. Maybe I have a bad receptacle
Old 10-12-2014, 06:45 PM   #12
Thanks everyone for all your help think I got it working if so it turned out to be a bad ground
Old 10-12-2014, 07:02 PM   #13
Good to hear.
12 volt
