Old 04-03-2013, 11:09 PM   #11
I think he meant using straight 12 V without going thru an inverter will require less power! Therefore battery will last longer with a 12V TV.
Of all the things I've lost in my life the thing I miss the most is my mind!
prairiecamper is offline   Reply With Quote
Old 04-03-2013, 11:30 PM   #12
Think we are splitting hairs . A conventional 24" led TV draws less than 30 watts. It's nothing .
Jim Scofield is offline   Reply With Quote
Old 04-04-2013, 09:21 AM   #13
Mountainmanbob's Avatar
Originally Posted by Turtle people View Post
Does this mean... The inverter/ tv combo uses less battery or a true 12V tv combo uses less battery?
true 12 volt I think to be the best
we have the brand below as I mentioned before
a fine 12 volt flat screen with DVD player
Supersonic SC-2411
Top Quality 12 Volt AC DC TV On Sale For $249.99 Free Shipping!
www.bundlecity.com/
Mountainmanbob is offline   Reply With Quote
Old 04-04-2013, 01:46 PM   #14
Why spend more than twice as much as you need to? Makes no sense
Old 04-07-2013, 12:01 PM   #15
cmcct's Avatar
It took some searching, my wife always gives me a wierd look when I do this, but I always look at the back of the TV's when I go to stores. There are not so many brands out there any more that use a small transformer from 120vac to 12vdc, but they are out there. Last year I found a 19" RCA LED LCD TV that used 12vdc input. I happen to have several plugs that have the same polarity as the TV power input, and they have an end that goes into a 12vdc power socket/cig lighter socket, and it works awesome. Best part is, with the LED back lighting, it does not use much power and it is now an HD screen, colours and clarity are way better than the older LCD unit I had before.
Tow Vehicle: '92 F350, Crew Cab, 4X4, Cummins 5.9 24 Valve, 6spd.Driver:Clint, Navigator:Melanie, 1 dog (Great Pyrenees/Akbash cross) and now a cat too. Mission Statement: Just another adventure! Towed vehicle:2009 Roo 19 with lots of mods!
cmcct is offline   Reply With Quote
Old 04-07-2013, 04:41 PM   #16
Turtle people's Avatar
After considering all the chooses, we purchased a Haier 24" LED/DVD HDTV... Even better I took it home for the official inspection and its a 12 Volt 3 amp. We also bought a 200W inverter to run it and charge phones/ radios while dry land camping. Just need to find the lighter plug too DC CABLE and were cooking with gas.
We found it at Visions $ 225 + $ 45 for a 7 year total replacement. Salesman said Rv electronics don't react to the moisture build up in the TT's.
Thanks a lot for all your help guys, we installed it last night but forgot to take pictures. I will post a follow up on a TT mod thread when I have all the pictures.
ID:	27320   Click image for larger version
Turtle people is offline   Reply With Quote
Old 04-09-2013, 09:27 AM   #17
Love My Sunseeker
DXSMac's Avatar
I have had good luck with Jensen 12 volt TV's. My last RV had one Jensen 12 volt and a Toshiba electric. The Toshiba went POOF. Jensen was fine. Current RV has three Jensen's, I'm happy!
JJ only, my cat went to Rainbow Bridge July 2015
I love my Sunseeker, when I'm on a trip I don't wanna go home!!!"
Total days camping each year: AS MUCH AS POSSIBLE!
DXSMac is offline   Reply With Quote
Old 04-16-2013, 11:59 AM   #18
moondog2000's Avatar
I am looking for a 22" tv dvd combo 12 volt.the Jensen being the most expensive,is it top of the line in your opinion.The haier also looks very good. If you don't mind my asking around how much do these tv's weigh. Thank You Mike
moondog2000 is offline   Reply With Quote
Old 04-16-2013, 07:49 PM   #19
I don't remember for sure, however when I was installing it I handles it with ease. My guess 4LBS... Here's all the specifications about the tv. And yes, I tried it out and looks really good. I have always found that smaller tv's look good only B/C the image is not being stretched
Old 04-17-2013, 02:26 AM   #20
Thank You for the info, How is the sound as some of the reviews on a lot of tv's it seems people complained about the sound, hope its ok as it looks good in the specs. Thanks Mike
