Old 07-26-2016, 02:52 PM   #11
Bilcin's Avatar
Originally Posted by Henboy View Post
While you are at it I suggest you change the frig light bulb to a LED.
If not switching to an LED light, will the fan blow the fuse when the light comes on?
Bill & Cindy McKenna
Philadelphia PA
2015 Palomino Puma 32DBKS
2005 Ford Excursion 6 liter Turbo Diesel
Bilcin is offline   Reply With Quote
Old 07-26-2016, 04:08 PM   #12
No, however that bulb is so hot it will burn your hand if you touch it. In my Flagstaff it was the last remaining filament bulb. All LED now, battery lasts longer and trailer is cooler!
I also installed a switch to turn off the door/humidity heating strip. (my frig did not have a switch on the panel). A big battery saver when not on shore power. We can now run the heater all night on battery. The heater safety switch disables the LP igniter unit when low battery voltage is detected, and that used to occur about 3:30 at night...BRRRRRR.
Henboy is offline   Reply With Quote
Old 07-26-2016, 04:53 PM   #13
Dennis3856
I made a fan from plastic white fence rails and two computer 12v fans with holes pulling air in the bottom and outputting at the fins. Ran wire thru the drain hole. Tales into supply wiring. Works great. Very cheep to make. Fence rail from Home Depot. Fans from Internet. Maybe $30 or less. Switch with light in front to power on or off.
Dennis Budreau is offline   Reply With Quote
Old 07-26-2016, 05:08 PM   #14
Flybob's Avatar
X2 Add a piggyback connector to the hot side and ground to fins and switch to LED bulb.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
Old 07-26-2016, 05:40 PM   #15
You already removed light cover now remove hot wire to switch stick wire from fan into shovel connector. And slide connector back on switch.then put light cover back on. You do not need to remove whole switch assembly.
Joe-Barb is offline   Reply With Quote
Old 07-26-2016, 05:53 PM   #16
Flybob's Avatar
Just get one of these at any auto parts store.
Name:	Piggy Back connector.jpg
TST Tire Monitors
2 65W solar panels
Old 07-26-2016, 06:14 PM   #17
bbbeebop's Avatar
Why not just buy the battery operated fan from Camping World
Bob & Laurie w/Missy
Sayre, PA
2016 Flagstaff Micro-Lite 21 DS
2015 Ford Explorer
bbbeebop is offline   Reply With Quote
Old 07-26-2016, 06:16 PM   #18
Bilcin's Avatar
Thanks! The girl and guy at radio shack were at a loss when I asked for a piggyback connector!
Philadelphia PA
Old 07-26-2016, 07:46 PM   #19
MacDR's Avatar
Originally Posted by jtatum65 View Post
If you got your fan unit from rvcoolingunit.com, the wire is long enough to feed thru the hole that the sensor comes thru and wire it directly to 12v on the backside of the fridge, thats how I wired mine.
X2 on pushing it through the hole that the sensor comes through, It looks cleaner and only takes a few minutes.
2013 Ram 2500 "Cummins"
2014 Columbus 340RK
Winterized until Fort Wilderness April 12-25 2017
MacDR is offline   Reply With Quote
Old 07-26-2016, 09:09 PM   #20
Stormrider151's Avatar
I ran mine down the drain tube. Super easy. Hooked into the 12 volt in the back of the fridge. I like this because it was a clean install and nothing will get tangled up in the wire.
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost
Getting old ain't for wimps!!!
Stormrider151 is offline   Reply With Quote
fan, refrigerator
