Old 07-26-2016, 10:35 PM   #21
Originally Posted by Dennis Budreau View Post
I made a fan from plastic white fence rails and two computer 12v fans with holes pulling air in the bottom and outputting at the fins. Ran wire thru the drain hole. Tales into supply wiring. Works great. Very cheep to make. Fence rail from Home Depot. Fans from Internet. Maybe $30 or less. Switch with light in front to power on or off.
I'd like to see a pic of your mod.
1988 Coleman Sequoia - popup (1987-2009)
2012 Roo19 - hybid (2012-2015)
2011 Traverse LT, 3.6L, FWD
2009 Silverado Ext Cab, 5.3L, 4x4, 3.73
rockfordroo is online now   Reply With Quote
Old 07-27-2016, 12:22 AM   #22
Bilcin's Avatar
Originally Posted by Stormrider151 View Post
I ran mine down the drain tube. Super easy. Hooked into the 12 volt in the back of the fridge. I like this because it was a clean install and nothing will get tangled up in the wire.
Never thought of that route!
Bill & Cindy McKenna
Philadelphia PA
2015 Palomino Puma 32DBKS
2005 Ford Excursion 6 liter Turbo Diesel
Bilcin is offline   Reply With Quote
Old 07-27-2016, 05:10 PM   #23
Captain America's Avatar
Like Flybob said..... get piggy back spade connector and slip on constant 12v supply at switch.
2011 Wildcat 32QBT
2006 GMC 2500, Airsafe 20K hitch, Air Lift Loadlifter 5000 air bags with Air Lift WirelessONE compressor
Jack of all trades, Master on none
Captain America is online now   Reply With Quote
Old 07-27-2016, 07:54 PM   #24
Bilcin's Avatar
Thanks for the picture! Hooked it up the same way and it works! And si I am clear about this the fan is supposed to attach to the fins and blow air over them?
Philadelphia PA
Old 07-27-2016, 11:41 PM   #25
10-4
2011 Wildcat 32QBT
Old 07-28-2016, 04:54 PM   #26
Bilcin's Avatar
Thanks for everyone's help.
Philadelphia PA
fan, refrigerator
