Old 07-25-2016, 07:55 PM   #1
Bilcin's Avatar
12v fan installation inside refrigerator
I want to install a 12v fan inside my Dometic 2652 refrigerator/freezer. Want to tap off of the light inside. I want to attach the power to the fan to the power for the light prior to the switch so the fan stays on as long as the refrigerator is on. On the picture, does anyone know how to take the light off the side of the refrigerator? Do I remove it or can this be done without removing the light to get to the wires?
ID:	115287   Click image for larger version
ID:	115288   Click image for larger version
Bill & Cindy McKenna
Philadelphia PA
2015 Palomino Puma 32DBKS
2005 Ford Excursion 6 liter Turbo Diesel
Bilcin is offline   Reply With Quote
Old 07-25-2016, 08:09 PM   #2
Don't have to remove it just ad a piggyback connector and plug it in.
2016 Flagstaff 23lb
Toddupton is offline   Reply With Quote
Old 07-25-2016, 08:43 PM   #3
Wa11y757's Avatar
I have same fridge and did the very same thing you are asking about. It seemed easy to pull the switch, tap into the hot wire, then put an alligator clip on the fans neg wire. To turn it on, I clip it to a cooling fin because they are grounded.
Now I'm going back to looking for my 10mm wrench! 2016 Wildwood 27RKSS
2005 F250 PSD
Wa11y757 is offline   Reply With Quote
Old 07-25-2016, 08:53 PM   #4
Bilcin's Avatar
2005 F250 PSD
Thank you for the reply. Pull the switch out of the light fixture?
Philadelphia PA
Old 07-25-2016, 11:49 PM   #5
Bilcin's Avatar
Ok, thanks! That makes it sound easy!
Philadelphia PA
Old 07-26-2016, 01:42 PM   #6
fan
I tried to install the fan on our fridge but every time I plugged it in the fuse blew outside. Instructions were clear but finally I gave up. I remember doing what you asked was not a problem but now It is gone from my head. I look at the fan sitting in my garage and still wonder why.
chevman
labarn is offline   Reply With Quote
Old 07-26-2016, 01:52 PM   #7
jtatum65's Avatar
If you got your fan unit from rvcoolingunit.com, the wire is long enough to feed thru the hole that the sensor comes thru and wire it directly to 12v on the backside of the fridge, thats how I wired mine.
Jim & Evelyn Tatum
2013 Rockwood 8289WS FW
2016 Dodge Ram 2500 Big Horn 6.4L Hemi 4x4
Nights Camped 2016= 31
# of Campgrounds= 10
Nights Camped 2015= 31 @ 7 CG
jtatum65 is online now   Reply With Quote
Old 07-26-2016, 02:37 PM   #8
Installed on the same fridg
u need to find the hot wire and connect with a piggy back switch or it it only work when you have the door open
Took me a couple of tries but no big issue
stervin is offline   Reply With Quote
Old 07-26-2016, 02:40 PM   #9
Bilcin's Avatar
Yes, was looking at that option this morning. I don't know who it was made by, got it from my friend who didn't need it anymore more?
Philadelphia PA
Old 07-26-2016, 03:11 PM   #10
While you are at it I suggest you change the frig light bulb to a LED.
Henboy is offline   Reply With Quote
fan, refrigerator
